1982 F250 Wiper Motor compatibility
Hi everyone,
I have a 1982 F250 and the wipers dont work. The **** has three positions,
which i believe to be OFF / SlOW / FAST, with full twist left being OFF. The **** pushes in for the wiper fluid.
I'd like to get one at a scrapyard for around $30 instead of 60 for an off brand new one, or 80-90 for Motorcraft version.
Is there an easy way to tell what (other) years have the same wiper motor?
The truck is a beater for weekend projects, so not in hurry on this.
Thanks
brad in ann arbor.
Thanks
brad in ann arbor.
Yes. Go to www.partsamerica.com and plug in your truck and look for a new wiper motor. Write the number down, go up and hit "change vehicle", plug in a different year truck, and when you are done it will go back to the wiper motor page, but give you the motors that fit that truck. Make a note of the part number and see if it matches the one for your truck. Keep doing this over and over for different years and you can find out what fits.
Originally Posted by brad1982f250
Hi everyone,
which i believe to be OFF / SlOW / FAST, with full twist left being OFF. The **** pushes in for the wiper fluid. I'd like to get one at a scrapyard for around $30 instead of 60 for an off brand new one, or 80-90 for Motorcraft version.
Thanks brad in ann arbor.
Fits: 1980/86 F100/350 & Bronco.
If your truck was made before January 1, 1982, the outlet arm must be changed.
Ford list price: $249.84 / FTE member net price: $132.44
emallen
37
01-27-2012 08:08 PM
bigdan1979f-250
12-23-2009 06:40 PM
