Transmission Question
Old Nov 16, 2007 | 12:31 PM
woodly1069's Avatar
woodly1069
Does anyone know if you can use an older three speed C6 or something in a 1994 F150 with the 302? The electronics in this thing are driving me crazy! Are the driveshafts, torque converter and flywheel compatible? Thanks in advance for any input
Old Nov 16, 2007 | 12:48 PM
mhg's Avatar
mhg
yes you can use a c6
will need the shaft to match the c6 length
dont know about the flywheel
will need the torque converter for a c6
may need a differant cross member
will need a differant ecm
one for a c6 or one for a stick
so it is not looking for the trans signal
Old Nov 16, 2007 | 04:43 PM
lostin90s's Avatar
lostin90s
The c 6 was could be had in F250 for awhile . So you may find the right ecu . Just get one for a manual truck . Along with shafts linkages dash indicator ETC. Hey they r a good tranny if I didn't need MPG I run 1
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
