still hard to handle
Ok I have replaced the ball joints in my 2004 SD and had the front end aligned. The truck still wanders all over the road. It has oversized tires on it and I was wondering if that could cause the truck to b hard to handle. I have also been told that these trucks do not have anything that returns them to center when steering?? Could this b the problem? I need help!!
Who ever told you that "these trucks do not have anything that returns them to center when steering" is full of it. When they are aligned properly they return to center. It just amazes me what people will tell a vehicle owner to get out of doing a proper repair.
Aside from no center return or feeling, does the truck exhibit any other symptoms like loose steering?
The symptoms could be ball joints, alignment or steering box.
Do not assume the ball joints are good just because they were replaced. Also do not assume the alignment is correct just because it was recently done. Did they give you the before and after measurements on the alignment? It sounds like they dialed in too much negative caster to me.
AFAIK, stock tires would be 235/85-16 , 275/65-18 , or 265/75-16.
Look at the printout, what are the alignment specs?
IMO: 305s on stock rims may be part of the problem, but I doubt it. They probably wouldn't give you symptoms like this unless you had a bad tire on the front axle or had the tires seriously underinflated.
