My 352 has C4AE 6090G heads, why?
Old 11-17-2007, 07:10 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
"Beemer Nut" is offline
High end high dollar performance engine building shops, maybe dyno shops as well. You'll have to call around. I don't have it at hand but there was a print out on some of the better FE heads and their cfm flow numbers.
Old 11-17-2007, 07:21 PM
Redmanbob's Avatar
Redmanbob
Redmanbob is offline
Yeah I am wondering about the after ported #'s. I assume the goal is to have each 1-8int & 1-8exh have equal flow numbers when done ? Dont know much of anything about a flow bench..I also assume unless your worried about 1/10000th of a second at the gates it's not worth the effort to have them benched ?
Old 11-17-2007, 08:24 PM
"Beemer Nut"
Equal flow on the heads is something that's good but think what a bad unequal flowing runner intake will do to that high dollar reworked head.
Old 04-05-2008, 12:29 AM
pauls67f250's Avatar
pauls67f250
pauls67f250 is offline
howdy! my 67 f250 maby 72 f100 moter
6090g thats what it say on my heads
iam allmost certain its a 352 or 390? need to dig
for more numbers, raining outside a night dont help. bla,
anybody whos readin this i originally had a stock with 2 barrel motocraft carb
intake c5ae94256 i swapted it for the same match numbers
for a four barrell intake so i could put this 4 barrell carter afb
625 cfm ok what have i not done right?
cant get it top dead center i thought most blocks were
or that are before 351s and 400 s are 15423578 on the roter
why am i havin so much trouble starting it ot setin timing
thanks much
Old 04-05-2008, 01:21 AM
Hypoid's Avatar
Hypoid
Hypoid is offline
Welcome aboard Paul!
It's kinda early...or late depending on how you look at it, so I'm not going to bust open any books right now.
If you look at the intake, you'll find cylinder numbers cast in by the valve cover, firing order cast on a runner somewhere. As a matter of fact, you can find it on that two barrel intake if you still have it.
If you didn't mark #1 on the dizzy, you might be lucky and have one of the caps with #1 marked. Past that it's a matter of turning the engine to get it indexed at TDC. The roter turns counter-clockwise.
BTW, you might get more people looking at your questions if you start your own thread. So don't be bashfull, some of us like doing stuff like this. LOL
Old 04-05-2008, 02:11 AM
pauls67f250
is it
does it sound like a 352
or do i got to set the timing to a rare 400 fe
or 351
or does it sound like 352 with 427 heads
that i messed up where its mark might be true?
or does you need more info on the block
thanks
Old 04-05-2008, 06:20 AM
jowilker's Avatar
jowilker
jowilker is offline
Paul, Which cylinder are you using for #1? Passenger side at the rad is #1 on a Ford just in case.
I'd say you have a 99% chance of a 352 in your 67. Many are called 390s few are.
The 351/400 first offered in 77, 351Ws in the 80s.
John
Old 04-05-2008, 09:37 PM
Hypoid's Avatar
Hypoid
Hypoid is offline
Time it as a 352, the other sizes of FE engines are pretty much the same specs.
Old 04-06-2008, 09:09 AM
pauls67f250
Time it as a 352
allright,
its funny ive allways been pretty good with cars
this snag can be embarrising i guess
like the red green show
thankya
Old 08-21-2016, 04:27 AM
winlit's Avatar
winlit
winlit is offline
Rusto794x4
22
07-27-2017 12:16 AM
Pruitt66
01-13-2017 10:45 AM
Nick-1973-ford
15
12-10-2016 05:03 PM
norvillebob
05-03-2016 10:22 PM
anthony myrick
02-17-2016 02:54 PM
Quick Reply: My 352 has C4AE 6090G heads, why?
