What to buy for a cold air intake
Old 11-12-2007, 09:40 PM
danyzf95
danyzf95 is offline
danyzf95 is starting off with a positive reputation.
In the market for a cold air intake for my 2000 any idea of what to buy and why?
Old 11-12-2007, 10:11 PM
bdrummonds's Avatar
bdrummonds
bdrummonds is offline
bdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud of
lots of different opinions, lots of different options. S&B, AIS, 6637(open element), volant.... the list goes on and really it will come down to which you like better. They all have good points and they all have downsides.
Old 11-12-2007, 10:14 PM
danyzf95
danyzf95 is offline
Please explain more. This is why I have posted.
Old 11-12-2007, 10:27 PM
F250_'s Avatar
F250_
F250_ is offline
F250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputation
First off, stay away from the K&N... it is not a good application for our PSD's. In a recent survey I ran, over 90% of K&N users switched to either the 6637, S&B, AFE, AIS, or some other intake.
Here's the link to the thread.
https://www.ford-trucks.com/forums/f.../poll2363.html
-6637 is cheap, but very effective (under $40 delivered to your door from FleetFilter)
-AIS seems to be considered the "cat's meow" on filtration efficiency in dusty conditions, but you PAY for it
-AFE is highly rated, filters as good or better than the 6637, but is much more expensive
- S&B is less known, but seems to have a good system, again, much more expensive than the 6637
Old 11-12-2007, 10:42 PM
white Buffalo's Avatar
white Buffalo
white Buffalo is offline
white Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud of
OK, I'll give it a try.....
The 6637 is used by many folks on FTE. It cost less than $50 to do it yourself and has shown very good results on used oil analysis reports. Prefered by the croud that loves to hear their turbo sing!
The Ford AIS was developed to improve the air filtration on vehicles operating in the desert environment over in Iraq. Also has very good oil analysis reports, the kit replaces the stock air intake system. The filters cost @ $80 and can last 25,000+ miles.
The AFE filters are preferred by the folks that have bigger mods on their engines that require a hell of alot of air. Also a very good system, cost over $300.
Everyone that has any of these systems is doing good for the engine and supplying losts of good clean air. It depends on what is the "end state" or the vision you have for your truck and backwards plan from there.
edit: I know nothing of the S&B intake, I have't seeen any oil analysis reports or talked with many folks that use them.
Old 11-12-2007, 10:44 PM
bdrummonds's Avatar
bdrummonds
O.K. sorry, for the vague answer. BTW WELCOME TO FTE.
A true cold air intake will have a box enclosing the filter media, and a intake tube that draws cooler air from the grill, or the fendersleeve(AFE stage2 ,AIS, S&B0. then we have the open element filters that draw air from under the hood(6637).
THEY ALL ARE BETTER THAN THE STOCK SETUP.
just stay away from an oiled filter(K&N)
Now the big question is how much do you want to spend. What mods have you done, what type of daily driving does this truck see. (hiway, dusty farm roads, water fording?).
there are many different variables that must be addressed, as there is no one is hands down better than all the others winner. They all have their strong points, and weaknesses.
AFE stage 2 +'s= great filtration, good airflow, lower intake temp, nice fit and finish
-'s= high initial cost, downtime while filter is washed and dried
S&B= see above
AIS +'s = great filtration, good airflow, FOMOCO recomended product, low down time (replaceable filter cartridge), lower intake temps.
-'s = high cost, no wow factor when hood is open( it is a factory severe service upgrade)
6637 +'s= inexpensive, Good airflow, Good filtration, low down time, readily avail, at most NAPA stores
-'s= higher intake air temp, more pronounced intake noise.
Old 11-12-2007, 11:20 PM
danyzf95
danyzf95 is offline
Thank you this is what I was looking for
Old 11-13-2007, 02:13 AM
ernesteugene's Avatar
ernesteugene
ernesteugene is offline
ernesteugene has a very good reputation on FTE.ernesteugene has a very good reputation on FTE.ernesteugene has a very good reputation on FTE.
If you want some more reading material, see post #6 on this thread...
https://www.ford-trucks.com/forums/670724-which-air-filter.html
... for links to most of the air filter threads for the past 6 months.
Old 11-13-2007, 04:45 AM
bruce51d's Avatar
bruce51d
bruce51d is offline
bruce51d is starting off with a positive reputation.
i have the s&b and i like it. not too noisy and draws cool air from outside the engine compartment. i got mine off of ebay for 194$ free shippin. pretty good deal if you ask me.
Old 11-13-2007, 10:22 AM
ToughBuiltFord
ToughBuiltFord is offline
FTE Sponsor
ToughBuiltFord is starting off with a positive reputation.
Well put guys...
You can also check out our shop's selction of CAIs to compare prices and customer reviews: http://motorhaven.autoanything.com/air-intakes/20A50096A1.aspx
Old 11-13-2007, 10:36 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
weekendwarriorfsw32 is offline
Master of Strokes
weekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud of
Another vote here for the 6637 Verry good air filter. Cheap and easy to install.
Nick
Old 11-13-2007, 10:43 AM
TurtleRacing's Avatar
TurtleRacing
TurtleRacing is offline
PSD Addict
TurtleRacing is starting off with a positive reputation.
Where are you guys getting you 6637? had Napa order me one and they didn't quote me a price, I went over to pick it up and it $55! I thought I saw them for $20 or so somewhere, am I crazy?
I'm on fleetfilter right now ordering the 6637, are their fuel and oil filters good too? I was going to order them while I was there.
Old 11-13-2007, 11:05 AM
F250_'s Avatar
F250_
F250_ is offline
Go ahead adn order two of the 6637's to reduce your per unit shipping, and then you'll be ready to change it out when it gets dirty and won't have to place a "panicky rush order".
For fuel filters, I would stick with either Motorcraft or Racor... don't remember who makes the Fleetfilter fuel filters. I'm using OilGuard's oil filters, which I think are actually made by Donaldson, if I remember correctly. Regardless, the Motorcraft oil filter is a good unit.
Canadianpowerstroke
12-08-2013 05:25 PM
dieselsmoker
6.4L Power Stroke Diesel
01-31-2013 03:43 PM
ford4ever72
2004 - 2008 F150
04-23-2012 02:51 PM
Johnlwlr
Modular V10 (6.8l)
24
04-03-2011 03:30 PM
cmcostan
09-10-2010 11:13 AM
Quick Reply: What to buy for a cold air intake
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
