1978 - 1996 Big Bronco
Bronco fuel pump question-
Old Nov 12, 2007 | 03:58 PM
351c's Avatar
351c
I have a '90 bronco with a 351w, I was wondering how many fuel pumps this thing has ? The ford repair manual says that it has 1 in the tank for the Bronco, But the drawings show one on the frame rail and the drawing is NOT for the diesel. I have found other problems with the factory repair manual so I figured I would ask you guys- Thanks fellas.
Old Nov 12, 2007 | 10:14 PM
carriljc's Avatar
carriljc
My 1990 351W only has 1 fuel pump...
it is in the tank.
Old Nov 12, 2007 | 10:15 PM
351c's Avatar
351c
Thank you-
Old Nov 12, 2007 | 11:00 PM
carriljc's Avatar
carriljc
you're welcome....
I've got the Ford Manual and it shows only 1 for our 1990 Broncos. I've repalced mine once, and we did my buddies 92 Bronco twice.....the first time we did his he didn't want to cut a hole in the deck so we dropped his tank. It was such a pain in the @zz that I went and made an access hole in mine...even though my pump hadn't failed. When my pump did fail, about 3 years later, it took me a total of about 45 minutes to swap it out.
The second time my buddies pump failed, he decided to make an access hole...
Old Nov 13, 2007 | 01:16 AM
351c's Avatar
351c
I guess that would make things alot easier, Luckily, this truck got a new pump just before I bought it.
