1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Where shuold I mount my CB?
Old 11-12-2007, 06:40 AM
matt0588's Avatar
matt0588
matt0588 is offline
I have a 2000 Expedition Eddie bauer. Any suggestions on where to mount my CB and if I should just use a megnetic small antenna or a larger whip type of antenna. Any help would be appreciated.
Old 11-12-2007, 10:25 AM
ArgoExpedition's Avatar
ArgoExpedition
ArgoExpedition is offline
Basically, anywhere you can find room. I know there isnt much so it will be a challenge. In my case I used a mag mount because Im not fond of drilling holes, and I mounted the radio sidways on the drivers side console running the cables to the firewall. Problem with that is the limited room to move the seat.
Oh, and for ideal transfer, cut the coax to a length in a 3 foot interval and coil up the spare under the dash. I have found that whips, and Ugly Sticks, provide the best transfer except for the whips bending in the wind thing that can change the wave characteristics. If at all possible find a friend that is a Ham radio operator, or even search online for more information. That would give you more info than I could provide.
Steve
Old 11-12-2007, 03:35 PM
NorthCarolinaExpy's Avatar
NorthCarolinaExpy
NorthCarolinaExpy is offline
CB install
I mounted my CB unit in the tray area and have it leaning on top of my coin slots. Its a small Uniden model and fits perfect. I then took the top off the CB unit and mounted a fabricated "L" bracket, slapped some velcro on the slanted part and mounted my XM radio unit on top.
For the antenna, I ran the coax from the dash back to the rear door. When I use the CB, I grab the magnetic mount and attach it to the roof then attach the whip. I have a K40 magnetic mount antenna.
Old 11-14-2007, 06:55 AM
matt0588's Avatar
matt0588
matt0588 is offline
thanks for the input. I mounted mine on the side of the console also.
ManfredVonRichtofen
1978 - 1996 Big Bronco
15
01-09-2017 11:30 AM
onug
2015 - 2020 F150
06-26-2016 11:57 AM
air1jpg
06-11-2008 04:09 PM
fredd
10-18-2004 10:22 AM
TN_Jeeper
1999 to 2016 Super Duty
10-13-2004 11:39 PM
Quick Reply: Where shuold I mount my CB?
