B20 @ 32 degrees
Old 11-28-2007, 11:29 AM
tazo's Avatar
tazo
tazo is offline
B20 @ 32 degrees
So it was 28 degrees out this morning was really worried about gelling. There was no problem and the truck started and ran fine. I was wondering what would be considered too cold for B20? Also I have to splash mix B99 with #2 diesel. How well does it mix? What I do is fill up with #2 diesel then drive a few miles to the bio diesel station and fill up the rest of the tank with B99. This is only my second tank with bio so I am new to all of this.
Old 11-28-2007, 08:23 PM
diverseth's Avatar
diverseth
diverseth is offline
Last month i was in Asheville and it got down in the teens and my truck started up no problem just MUCH quieter. I was using B20 that I got from a Texaco station without any additive. It was my first time using BIO so I was a little nervous but my truck ran awsome in the BIO.
Old 11-28-2007, 10:23 PM
MikeSDK's Avatar
MikeSDK
MikeSDK is offline
Go to biodiesel.org and look for articles on cold weather performance. I am also running B20 exclusively, here in Nashville. It has gotten down to the high 20's, and I've had no issues..
If I remember correctly, I think I saw where B20 should be good to around 5* to 10* (may have read the graph wrong) without additive like Diesel Kleen.
Old 11-29-2007, 09:28 AM
tndiesel's Avatar
tndiesel
tndiesel is offline
I also live in Nashville, where do you get it in Nashville? I want to try some bio in my 7.3.
Old 11-29-2007, 09:41 AM
MikeSDK's Avatar
MikeSDK
MikeSDK is offline
Here is a link showing sites of filling stations in TN that carry bio:
http://www.biodiesel.org/buyingbiodi...tate.asp?st=TN
I generally get mine at the Shell station at the Long Hollow Pike exit (Hendersonville) on I-65 N....or, if I am near Brentwood / Franklin, the
Shell station at the Moore's Ln / Mallory Lane intersection also carries B20.
There are several other stations locally that carry it, but those are generally the ones that I am near most often.
Runs great!
Old 11-29-2007, 10:30 AM
tazo's Avatar
tazo
tazo is offline
Thanks for the info guys. I get a bit nervous with this truck. It seems to be extremely sensitive to change. The check engine light went on this morning. I will have to get my code reader and see whats going on.
Old 11-29-2007, 10:51 AM
MikeSDK's Avatar
MikeSDK
MikeSDK is offline
Guys, remember to be sensitive about changing your fuel filters frequently for a while after switching over to bio. It is a solvent, and will clean your fuel system of the crud #2 diesel leaves in there....and it ends up in the filter.
I changed mine at oil change intervals (@5000 miles) the first few times after I switched.
Old 12-04-2007, 02:46 PM
tazo's Avatar
tazo
tazo is offline
http://nbb.grassroots.com/08Releases/cold/
Thought I would share this with everyone.
Old 12-05-2007, 09:06 PM
Fat Diesel's Avatar
Fat Diesel
Fat Diesel is online now
I didn't notice anything unusual when I started using BIO, but my fuel system is really, really clean as evidenced by NOTHING being in the tank after 100k miles.
BUT- I do notice my filter on my Dahl 100 pre-pump filter clogs faster on B99 than on #2. Not sure why, since there is a big ol filter right on the pump as it comes out...
I use a combination of my fuel pressure gauge in the cab and a vacuum gauge mounted between the filter and the pump to monitor the status of the filter. Pressure drops down to, oh about ZERO psi at WOT if I let it go too long!
HamRad
05-23-2014 11:28 AM
John with beastly 302
Bio-diesel, Propane & Alternative Diesel Engine Fuels
03-20-2008 06:02 PM
WonderDonkey
11-21-2007 08:26 PM
RedStroker6
13
05-08-2006 04:14 PM
Quick Reply: B20 @ 32 degrees
