Programing
Old Nov 11, 2007 | 09:44 AM
dragonslayer's Avatar
dragonslayer
Question Programing
Is there or does anyone have a reprogramer for 1994 F-150.
Old Nov 13, 2007 | 05:44 PM
fordnut1985's Avatar
fordnut1985
I think Hypertech makes one but to be honest you won't notice a whole lot of power gain.
Old Nov 23, 2007 | 08:15 PM
dragonslayer
The problem I`m running into is that the motor I put in is running hot according to the temp gauge. I might need to change the thermostat.
Old Nov 23, 2007 | 10:18 PM
Ultramagdan's Avatar
Ultramagdan
If the gauge is C - H then I would question the gauge. Check your thermostat before tossing it and if you still have issues consider an accurate gauge.
Old Nov 24, 2007 | 01:43 AM
dragonslayer
The gauge that I have is a \NORMAL/ type gauge and it has been running into the AL of the gauge. When this motor was in a van it read the same. I`ve noticed that when it gets this hot the motor wants to chug and not run smooth. The radiator is full with 50/50 antifreeze. New equipment from the plugs to rotor and ingnition coil. Also when it gets this hot the motor if it has been running at highway speed, and I drive into a parking lot the motor stalls, and is very hard to get started again till it cools down. Then it will act fine untill the temp comes back up.
Old Nov 24, 2007 | 10:53 AM
fordnut1985
Double check your timing and plug wire locations, make sure all the wires are separate from each other. You might also pull the ignition module and have it tested, most local auto parts stores do it for free but make sure they test it 8-10 times so it gets good and warm which is when it is most likely to fail.
