AOD cable, Factory or aftermarket?
Hey guys, I have an 86 ford 150 that in another life had a very worn out efi 302 with AOD. I put in a 302 that had been "perked up" a little. I'm not sure which cam was installed, as I bought the engine from another individual that built it. He told me all the specifications but I have since forgotten, as it was several years ago.
The problem was, it was not compatible with the computerized efi and ran really rough. Being from "old school", I choose to remove the efi and go with a carb.
I used Edelbrock with Holly 600. The question is, is there any way to use the original TV cable with the Holly carb, or will I have to find an aftermarket cable?
Thanks,
Bob
Thanks,
Bob
Thanks guys, I have contacted Lokar and they do have what I need but they are really proud of it. I was hoping someone else had ran into the same problem as me and found a way to use the original cable, since I already have it. I think I can build a mounting bracket for it to connect to the carburator, given enough time, but it sure would be nice to know a short cut if there is one.
Thanks for the get back. I appreciate it.
Bob
Bob
