lifting a S/B 94.....
#46
#47
#48
Originally Posted by 351slug
I guess ive been lucky with my driveshafts not vibrating with lift. I only have like 4 iches of lift in rear and 6 inches in front. So far so good. 96onefifty, that looks sweet. Alot of angle out back,wow.
#49
Originally Posted by 96onefifty
thanx, yeah it vibrates like no other on take off, still trying to find a solution.
#50
If you shim the diff and lower the crossmember and trans case about an inch, you won't have ANY trouble at all. I have 8" skyjacker and 2 inch body with this done and i cruise on the highway at 70-75 all day with no vibes for 3 years now, and i just changed my u-joints. Make sure you put a good set of u-joints in with the stock driveshaft and you'll be fine!
#52
I've had the truck lifted for 3 years now and not a single problem! I made a set of motor mounts so the hole drivetrain is sitting on an angle. Bad ideas sometimes come from people who don't know what there are doing and that's why it's a bad idea. I have my truck to the dunes about 15-20 times a year and i beat it pretty good and still no issues, so i guess it all depends on the truck and equipment!
#53
94 supercab
01-25-2004 04:32 PM
