OEM Overhead console retrofit for Super Duty
#31
Originally Posted by Bulldog68
5 Holes??? Don't you mean 15? I know cause I just put mine on two weeks ago. 1 hole is enough for me, but 15, good god. Glad I got it right the first time. Lol.
#32
#33
Originally Posted by bwestcott
Wild - Please post once you've got this installed. I desperately miss having the console that I had in my 150.... I'm not thrilled about how expensive these are, but if it goes in easy, it just may have to happen. Good luck with the weekend projects
#34
Originally Posted by WildWildWest
I'm less worried about cutting a hole in the headliner (template provided and really clear instructions) than I am about drilling 5 holes in my roof to install the clearance lights - which I am doing at the same time this weekend - then I only have to drop the headliner once.
And yes, the roof does have supports built in that you can screw the console into. The ebay seller (Ol Bird) installed his in his '07 super duty and the pics are clear that the roof supports are there to screw into. To my knowledge, they haven't changed the roof in the Super Duty trucks - the older ones had the console as an option and the newer ones still need a place to install that goofy modular snap in rail overhead system in the '05 and up that you can attach a kleenex holder and rear DVD system to.
#35
Originally Posted by blackhat620
The SD Never used the overhead rail system. The overhead rail system is use in the F150 not a SD.
http://www.fordaccessoriesstore.com/...Super_Duty.PDF
#36
Check out page 10 in the following link - it shows the overhead rail system for the F250/F350 on Lariat models and the modular options for it.
Notice page 10 of the F150 accessory catalog
http://www.fordaccessoriesstore.com/.../2006_F150.pdf
That option is also not available in the online version of the catalog, just the archived pdf file of the catalog
www.fordaccessoriesstore.com/fas/b2c/catalog.asp
See page 12 of the 2007 SD accessory catalog and it shows the picture of the overhead console that was installed in all 05-07 Lariat SD without a sunroof. Sunroof version much smaller.
http://www.fordaccessoriesstore.com/...Super_Duty.pdf
#39
Got the overhead console installed - easy to wire up - hardest part was cutting the hole in the headliner!! Great instructions from Ol' Bird. I installed my cab clearance lights while I had the headliner down. My console only has temperature and compass. I put the Recon smoked clearance lights and amber bulbs and I like the looks - the orange bulbs make them look like big LED's. Trucks is dirty - we were out hunting mule deer on Monday after getting skunked on Elk Friday and Saturday.
#40
#42
#43
#44
Just type in ol bird in the user search on ebay, or there is an ebay link in one of the posts at the beginning of this thread, which is already closed, but you can scroll down and it will show other items for sell by this seller or something along those lines. That is how i found it the first time. I'm hoping to put my console in this coming week.
#45
