Synthetic CJ-4 Oil?
#31
#32
Originally Posted by skl
Thanks for the heads up. Could have sworn looking at their literature it was CJ-4- will put on my reading glasses tomorrow and verify when I go to buy it. Otherwise I'll use the online place you mentioned.
#33
#35
Originally Posted by avmike
My mistake, the company is Chevron not Exxon.
If you saw Chevron Delo 15W-40, it is a dino oil, check the labeling on the package closely.
http://www.chevrondelo.com/en/delowo...co/default.asp
http://eolcs.api.org/DisplayLicenseI...LicenseNo=0090
#36
It helps to put on the reading glasses... the Valvoline 5-40 is NOT CJ-4 so I ordered some Mobil 1 ESP online- got tired of calling around and not finding it here yet. Maybe by next spring but a case of the Mobil 1 will last till then...5-40 synthetic should crank over a little easier this winter!!
#37
#38
I bought 2 cases of Duron E Syn 10-40 oil. In my area area, central BC, ford only carries dino 10-30 which according to the owner manual isn't the proper winter oil for my area. Luckily I read about Petro Can having syn CJ-4 oil on this board still when I asked for it in Vancouver, BC no one had it and I was refered to Prince George. So I called Prince George Petro Can and got them to reserve 2 cases for and picked up a few days later on my way through. The only modification other than winter tires I'm planning is the instalation of a FS-2500 By-Pass oil filter.
#39
ALREMKIN:
I need to change oil in Chilliwack, BC area. Mobil DELVAC 1 ESP 5W-40 will not be available in BC until January. The Petrocan Duron*-E API CJ4 in synthetic oil seems to fit the bill except it is in 10W-40 not 5W-40. I live in a cold climate like you yet will be towing a 5th wheel in California this winter. The Ford Manual only recommends the 5W-40 or 15W-40 for trailer towing. Will the 10W-40 meet this and keep Ford happy with warranties? If so, where can I find the Duron besides PG?
#40
Originally Posted by pilotshot
ALREMKIN:
http://www.mobil.com/USA-English/Lub..._ESP_5W-40.asp
www.petro-canada.ca/pdfs/IM8028e.pdf
#41
Does anyone here know if installing a FS-2500 By Pass Oil Filter will void the Warranty? It a complicated issue with the oil testing to extend the period of the oil changes, but from what they say at the FS-2500 site with testing you can get 100,000 miles or more between oil changes with much less wear on the engine than normal oil changing it every 5k miles. I imagine the sticking point would be if/when there's engine damage one would have to have proof of following proper proceedures.
#42
www.bobistheoilguy.com/
www.bobistheoilguy.com/forums/ubbthreads.php
As far as warranty issues, that is iffy at best. FMC has come down pretty hard on the 6.4 and modifications. Read your FMC Warranty manual and oil change intervals in the Supplemental Diesel manual carefully (see pages 41, 42, 55. FMC states that all oils even sythetic must be changed per the interval outlined in the FMC manual. Also read any other documentation you signed from FMC during your purchase.
I am not saying you cannot potentially run extended OCI with a bypass system and following the advice of the UOA, but you need to do some research on this over at BITOG. Filter Solutions is padding the results from their bypass system quite a bit.
#43
Hm, ok I've had a first look at the oil site. What would you say a reasonable OCI is with a By-Pass filter once a year or 25,000 miles? The basic idea of super cleaning the oil seems a good, but it also makes things more complicated with warranties and what not. This is compounded by the fact that I live in a cold winter area central BC. I like the truck and would like to see it last 20 years, that's my motivation.
#44
You are using a good synthetic oil, and with bypass filtration you may be able to get to a 15K OCI, just really hard to say since the engine is so new. On the 6.0 with its HPO fired fuel injection system & EGR system, 7K is about the max OCI obtainable.
The factors that determine OCI are more than the cleaner oil do to the bypass filter, you also have add pack degredation and oil shear. The two main things that are looked at on UOA reports for oil life is TBN & Viscosity. When either of these reach there minimum threshold the oil must be changed. The new 6.4 with its EGR & DPF systems, dump alot of soot in the oil, yes ULSD is supposed to help reduce this, and the new API CJ-4 oil is supposed to help with this as well, but currently there just is not enough long term information on the motor to determine how long and OCI can safely be achieved.
Since your main concern is longevity, i would install a bypass oil filtration system either Oil Guard (FTE Sponsor) or Filter Solutions. Even if you do not achieve a long OCI, the benefit of cleaner oil do to the bypass filtration will result in less wear on the motor. In addition i would definitely install a coolant filter from Dieselsite (FTE Sponsor). Coolant filters are very important, as the casting sand in the motor causes the oil coolers to plug & fail and the water pumps to fail prematurely.
www.oilguard.com/Ford6.php
http://www.dieselsite.com/index.asp?...RODGROUP&ID=13
#45
FORD SERVICE BULLETIN UPDATE-6.4L PSD OPERATING & MAINTENANCE REQUIREMENTS: DATED 11/16/2007
I will summarize the bulletin to save some space on this thread
OIL
A. Use only engine oil SAE viscosity for the anticipated ambient temperatures contained in the Owner's Manual
B. Use only Motorcraft or equivalent oil conforming to Ford Spec WSS-M2C171-E or CJ-4 or CJ-4/SM.
C.Motorcraft CJ-4 5W40 oil is expected Jan. 1 2008. At present there is no availability of Motorcraft 5W40,0W30 or 0W40.
COLD STARTING
A. Idle engine for 30 seconds prior to incresasing RPM. The Owner's Supplementary Guide presently shows 15 seconds. It will be updated.
B. Use block heaters below temps of -23C/-10F.
C. Use only ULSD Fuel Cetane Additives and/or Anti-Gel that are intended for the ULSD 6.4 PSD.
D. Do not use alcohol based additives as it may damage the fuel injectors/system.
E. Remember to replace both fuel Filters at same time. Some after market suppliers miss the FCM/HFCM under the rail. It will result in hard starting, driveability and injector damage.
F. Drain the water from the FCM/HFCM Fuel conditioner Module under the rail monthly or when WATER IN FUEL warning light comes on, which ever occurs first.
D.
OIL
COLD STARTING
D.
