Sponsored by: Real Truck
front end noise
Old Oct 28, 2007 | 01:08 PM
johnconnor's Avatar
johnconnor
front end noise
My truck has an intermittent vibration and noise from the front end sounds like the drivers side. The problem goes away when put into 4wd. It has auto locking hubs. 99 f350 v10. Are the hubs most likely the problem?
Old Oct 28, 2007 | 01:16 PM
Jim59's Avatar
Jim59
If the noise GOES AWAY when you lock in the hubs, look immediately at the needle bearing .... you may be destroying the axle end
I can only speak for manual hubs, though.
Good luck.
Old Oct 28, 2007 | 01:19 PM
johnconnor's Avatar
johnconnor
The hubs are set on auto and the noise goes away when put in 4wd hi.
Old Oct 28, 2007 | 01:27 PM
Jim59's Avatar
Jim59
Someone correct me if I'm wrong ....
when a hub is not locked in, the axle end spins freely inside of that needle bearing. Unfortunately, these needle bearings sometimes run dry of grease. First the bearing goes bad, and then it starts to damage the axle.
When a hub is locked it, the axle is no longer spinning inside of that needle bearing --- it is rotating with the wheel/hub/etc; therefore, the no damage is being done then
just my 2 cents
