Aero150
Welcome to this forum.
Can you elaborate, what are you trying to donate from the F150 to the Aerostar? The engine?
Someone has installed a 351W into an Aerostar:
https://www.ford-trucks.com/forums/2...erostar-2.html
but I think they said that a mod motor will probably not fit; the Aero's engine compartment area is too small.
The 4.6 is wider than the 351W.
Dimensions:
https://www.onallcylinders.com/2018/...al-dimensions/
Get the tape measure out....
Dimensions:
Dimensions:
Dimensions:
The venerable small block Ford is probably the most compact American made v8, and it has been installed into an Aerostar without major cutting. Looks like it's been done before:
https://www.cargurus.com/Cars/Discussion-d318_ds550203
So it's probably the best choice.
