Is the 120r worth it
Originally Posted by santacruzf250
I'm just curious to see if I'm on the right track. The reason some people can't take full advantage of the 120R is because they have weak HPOPs, right? But the Stage 1 SS's use less oil. So with S1SS's and the right tuning, you should be able to produce the most power without going to Big Oil?
I said mine just smokes more in the 120 and seems no faster than the 80. If my turbo was up to the task and the fuel wasn't, it wouldn't smoke at all. That is just on my truck. Lotsa smoke means enough fuel.
BTW, you are correct. The stage 1 SS will provide more fuel with the same or less HPO.
