Oil Pressure sender?
yes, if you truck has a oil pressure gage. It is located UNDER HOOD, DRIVER SIDE, LOWER ENGINE AREA, ABOVE OIL FILTER, MOUNTED IN ENGINE BLOCK. It will be screwed into the block with a wire connected to the other end. Its a round part that is usually silver or gold, you can't miss it.
From too much gasoline running down the intake into the cylinder's then breaking down the lubrication of, Now non-existing oil on the rings.
Dennis
F.T.E. Assistant Administrator
[font color=red]
"May The Spirit Of Christmas Be An Inspiration To You Throughout The Year"[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Dennis
[font color=red]
