460 thermostat housing predicament
on
ok... ready for the next challange...
460... using Performance distributor (HEI = big sucker)
had to get a modified thermostat housing to clear the distributor
realized today that the housing is pointed directly at the back of my shiny a/c compressor AND in perfect alignment with my serpentine belt.
tried to think of a work around and looked at 100K pictures of housings on the information cul-de-sac... found some possible fits but high $$.
I need to still be able to clear the distributor housing AND point the hose in a different direction... mostly straight toward radiator.
I'm trying to find a swivel housing that will clear the dist and still turn the hose but can't seem to find a 460 version
questions.... Will another version of ford engine 302,351,400 ?? work on a 460 performer manifold ??
My afternoon project was an attempt to make one. I've got the mounting flange cut out of 3/8 plate and ready... I'm thinking of finding another 460 housing... cutting off the neck where it attaches to the flange and welding it together... or...
fabbing one up out of some tubing (if I can find 1-1/2" stuff... that might be the best choice cause that existing housing looks like cast iron...and that don't weld good do it ???
... pics below... I'm open to all suggestions
thanks
John
if ya'll keep hanging around... I'm gonna keep coming up with these problems
thanks
John
on
time to start scrounging stuff.... ya'll work on this tonite.... I"m going to bed
thanks, I'll pick it up in the morning... and ah... the stainless would look good polished
Out of curiosity, how would you go about fabricating one of these from scratch? I would go with the Summit Racing option because I wouldn't even know where to start when fabbing!
Looking at the summit piece, if you had a bunch of tools I could see buying 4 pieces of steel - 2 tubular pieces, one bigger and one smaller to match the pattern on the summit and two flat pieces. One becomes the piece that is bolted on the engine and the other is welded to the larger tube. But now it seems like you would have to bevel out enough on the piece that bolts to the engine to allow the other flat piece to fit under it and allow the larger tube to turn. Is this how it would be fab'd?
on
on
that is sorta what I'm thinking Jerry.. I've already cut and finished the bottom plate (flange) that mounts to the manifold. Now I'm cyphering the best approach to the rise and run for the neck and avoiding the distributor housing...
@NB ... that would also work, but I like the Performance Dist and got $$$ invested here. Wandering the net I see that this is already a known problem but my ideal solution still eludes me.
j
on
so here's todays progress... spent yesterday gathering up SS pipe and fittings and making a new flange in SS
I've found nothing commercially that will work... even the flat flange with a straight 1.5" nipple will interfere...
so... here's my latest try... get this tigged up and polished and maybe it won't look like homemade hammered dog **it
last shot is with the camera at the radiator connection point so the rise and bend won't be too bad
john
john
460 in a 1997 f250 problems
j
j
