Too much oil?
Old Oct 22, 2007 | 09:04 PM
guitarpicr's Avatar
guitarpicr
Too much oil?
Changed my oil last week and checked today & its a little above hash marks on level ground when hot. Should I drain some out or is it critical. It was @ 1/4" above top of mark.
Old Oct 22, 2007 | 09:37 PM
bdrummonds's Avatar
bdrummonds
how many QTs did you add(including filter) when you changed it. 1/4 inch of depth in a pan as big as ours is a good bit. the only thing about overfilling is the possibilty of frothing from the crank. I am sure there is a overfill tolerance built into the pan but I am not sure what it is.
Old Oct 22, 2007 | 09:59 PM
guitarpicr's Avatar
guitarpicr
I only put in 15 when I first changed and then when I checked it it showed a little low so I added the last quart. I only had 4 gallons to start with. It might only be 1/8 " over . Thanks
Old Oct 22, 2007 | 10:11 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I doubt this is a problem unless you notice injector noise or performance issues from potential frothing or foaming which a good oil shouldn't do anyway.
