Cant Find Hedman Headers
on
for 80-96, the chassis is the same between the 2wd and 4wd, I had no problems with the Hedmans on my 300 with the truck set up either way.
With the 300, what tranny you have doesn't make too much difference, as the clutch linage, or shifter linkage is on the opposite side of the engine.
Evan
86 F250 HD XLT Lariat Explorer 4x4 ex. Extended Cab: 460 with factory 2.25" catless duals to the muffler(still running the stocker aaargh)
/T19(syncroed granny low)/BW 1345/3.55 geared Full Floater 10.25 and Dana 50 TTB/ 265/75R16 Hankook FR04's on 16x8 Whitespokes(street tires... Need mudders)
78 F150, 351M/C6, eventually to be repowered with a 400
Evan
[updated:LAST EDITED ON 27-Dec-02 AT 07:17 PM (EST)]The number posted above sounds right. When you look up the application it won't show the headers to fit anything past 89, but they fit all the way up to 96. At least that's how it was when I bought mine. Here's the link to Summit's listing:
http://store.summitracing.com/partdetail.asp?part=7075
The listing says 2wd only, but I've compared my truck (1990) to an 89 4x4 and couldn't see anything to keep them from fitting the 4x4.
