Excursion V10 swap to 5.9 cummins... - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 03-30-2011, 12:41 PM
5.9Excursion
5.9Excursion is offline
5.9Excursion is starting off with a positive reputation.
Has it been that long? ha ha
I got about 10.8 mpg with the V10 before the swap. Last time I checked I was getting around 16.5 mixed driving with it after the swap. The power/torque available now is way more than before (not to say the V10 is a slouch either).
I developed a trans leak a while back and after pulling the trans I found out the torque convertor snout that drives the oil pump had sheared off. I ended up putting a single disk back in it as the triple disk was too harsh for what we use it for. Hopefully by friday I will have it back on the road.
My website has a link to a full build writeup of my swap if you are interested.
Main
  #47
Old 03-30-2011, 01:47 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
I'm glad to hear from you again, as I'm sure several others are and hope you start posting a bit more often as I'm sure you have a lot of knowledge to share.
Thanks for the comeback.
  #48
Old 03-30-2011, 01:58 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
That is an awesome Dodge sled puller, I have seen it on TV and youtube and it is very impressive. Do you have a truck shop in Nebraska?
  #49
Old 03-30-2011, 02:39 PM
5.9Excursion
Thanks, it has slowly progressed to be quite a runner. I was at the hp limits of the driveline this past year (limited to a factory one-ton or less) driveline by the class. Even with bigger driveshafts, bigger yokes, 300M axles, etc I still broke stuff about every other pull. So I decided to jump up another class so I can run open driveline. I'm building a new engine as well so it may be next year before it is ready to run. Here's a video from last season:
YouTube - Jesse Neddenriep, 2.8 Diesel, Stanberry, MO 2010 - It's Only Money
And here is a shot of my new billet dropbox/reverser (this replaces my factory transmission and transfercase).
I'm in the process of building a new shop right now.
  #50
Old 03-30-2011, 03:10 PM
excursiondude's Avatar
excursiondude
excursiondude is offline
excursiondude is gaining momentum as a positive member of FTE.
Hi 5.9 I'm glad I took a shot and resurrected this thread. I am getting ready to start this with my 02 excursion. I want it for the mpgs and to tow my rv with the family. Cummins rock I just need to find the right donor truck. I'm looking for a 94-98 ram. 12v easy engine.(easier LOL)
anyway welcome back
  #51
Old 08-08-2013, 01:14 PM
ExSKARsion
ExSKARsion is offline
ExSKARsion is gaining momentum as a positive member of FTE.ExSKARsion is gaining momentum as a positive member of FTE.
Does anyone have a rough estimate of cost associated with a swap like this?
I have heard the 5.9 12v Cummins were the easiest swaps to do and I've seen quotes anywhere from 2,000$ to 10,000$.
If I can manage to get at least 1,500$ for my freshly rebuilt 6.8L V-10 then how much more would I be looking at? I have seen the cummins with less than 100k for between 1800-3500. Most come with trannys as well.
Thoughts?
  #52
Old 04-10-2016, 04:21 PM
rob.hvac
rob.hvac is offline
rob.hvac is starting off with a positive reputation.
Hey 5.9excursion I did the same swap but I used a 12 valve. I'm having a problem with the tach I'm trying to still have the mpg screen still work, how did you tie it in?
Thanks in advance
  #53
Old 04-16-2016, 08:33 PM
gots_a_sol's Avatar
gots_a_sol
gots_a_sol is offline
gots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant future
OP hasn't been here since 2011, so not likely to get an answer from him.
BUT, I did mine by using a tone ring with the same tooth count as the v10 and just used the original crank sensor to read it. One of the conversion companies has a kit to do the same, I cut out my own since I'm cheap.
  #54
Old 10-13-2016, 08:56 PM
largrizzly
largrizzly is offline
largrizzly is starting off with a positive reputation.
Love your build in the middle of doing the 12v p pump swap now with zf 6 manual trans did your get all the acc. to working right ie cruise and AC just need some help have moved the cruise module have to make spacer did your x done have cruise
  #55
Old 10-25-2016, 10:28 AM
gkerney88
gkerney88 is offline
gkerney88 is starting off with a positive reputation.
Few questions
Looking to do this to my 05 Excursion. I thought about doing the diesel conversion adapter to my 5speed. But if I can save some money and use the tranny out of the donor dodge I get the 5.9 from I'll do that (Plus get a better tranny)
So here are my questions.
What year motor/tran did you use?
How has the gearing worked out since install?
Did you have to make custom motor mounts to get it all lined up? Or will a diesel conversion adapter mounts work in the stock location?
Thanks for sharing. Looking forward to my build.
Nope, its a 2001. 24V with vp44 maxed out...
  #56
Old 10-25-2016, 04:47 PM
cumminslyfe
cumminslyfe is offline
cumminslyfe is starting off with a positive reputation.
6.0 died looking to do a swap
Ok so I have a 6.0 and it died with the typical EGR head problems I found a 5.9 Cummins 12V in a 1995 F-600 or 650 is that motor the same as a dodge 12v? I called a company looking to get information on what I will need for the swap and they are saying it will not work. Does anyone have any ideas or experience to back that up? Also what I will need to do the swap. Im new to the forum and im hoping I can get good insite
Thanks in advance
Patrick
  #57
Old 10-25-2016, 05:54 PM
gots_a_sol's Avatar
gots_a_sol
A cummins is a cummins no matter where it is from (save for ones in generators and equipment which have a different style of injection pump compared to automotive ones).
Whoever you called might have thought you were talking about a big cummins and not the B-series.
What all you need to do the swap? A lot of time on google. Biggest decisions are going to be what engine/injection pump and what trans you are going to use.
  #58
Old 10-25-2016, 06:20 PM
cumminslyfe
thats what I thought I was planning to use the transmission the truck already has is that not a good idea?
  #59
Old 10-26-2016, 10:30 AM
biz4two's Avatar
biz4two
biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Arrow
That depends on what trans that truck is running. Things to consider are the gear ratios with the trans and the truck you want to swap the B-Series into.
You did not mention if you have a 4x4 or not. That also must come into consideration for the donor trans to transfer case bolting up.
biz
meatloaf_CC
380
02-26-2018 02:01 PM
crsweet78
143
02-01-2018 11:41 AM
crazyredneckanyhow
Ford Truck Parts for Sale
04-16-2017 02:31 AM
andyort
Engine Swaps
30
03-05-2017 03:53 PM
fire240
2009 - 2014 F150
86
10-05-2016 06:28 PM
Quick Reply: Excursion V10 swap to 5.9 cummins...
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
