Excursion V10 swap to 5.9 cummins... - Page 2 - Ford Truck Enthusiasts Forums
Old 10-30-2007, 01:52 PM
5.9Excursion
5.9Excursion is offline
5.9Excursion is starting off with a positive reputation.
Got my 2001 truck dyno'd this weekend. Didn't have time for tuning and didn't spray the water/meth. Ran on injectors alone and put down 462 hp 1001 ftlbs. With the one combination of boxes we had time to try it put down 593 hp 1340 ftlbs. I figure with some tweaks on the settings and spraying water/meth I would have been close to 650 hp. Always next time I guess...
Here's the video from the 593 hp run... http://www.youtube.com/watch?v=zIkK60tT_JA
Last night I was able to do the relentless diesel DIY stage I mods to the cp3 for the excursion engine. Should start on it this weekend (the swap).
More to come...
Old 11-05-2007, 07:45 AM
5.9Excursion
Got another 4 hours to work on it yesterday. Went pretty well, got the engine and transmission removed. Here's the pics...
Old 11-05-2007, 05:45 PM
barnbuoy's Avatar
barnbuoy
barnbuoy is offline
barnbuoy is starting off with a positive reputation.
wow-you got bigger ones then me!
Old 11-05-2007, 07:50 PM
throttle's Avatar
throttle
throttle is offline
throttle is starting off with a positive reputation.
If you still have it, how much you asking for the engine and trans? Thanks
Old 11-05-2007, 08:53 PM
5.9Excursion
throttle, check your PM's.
I got some small stuff done on it tonight. Removed the brake booster, vacuum tank, cruise control system, PS hoses and gear box (replacing it with a new one).
Old 11-06-2007, 10:04 AM
barnbuoy's Avatar
barnbuoy
barnbuoy is offline
this is the point i would begin to lose interest and start another project......i currently have about 27 projects....
houses, boats, cars, trucks, and then there's this stupid work thing...
Old 11-11-2007, 09:34 PM
5.9Excursion
Latest pics...
Tranny is next. Transfer case input shaft has been changed over and is ready to install. Then the new exhaust system...
Old 11-11-2007, 09:43 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
That is an AWESOME project you have going there. Keep up the pics and good work.
Old 11-15-2007, 10:38 PM
beansdiesel
beansdiesel is offline
beansdiesel is gaining momentum as a positive member of FTE.
looks familure , let me know if ya need any help. Got two more CR swaps goin down in the shop currently, one is accually a 6.7.
Old 11-16-2007, 08:50 AM
5.9Excursion
beansdiesel, do you use the ford or the dodge intercooler? I have both, just need to trial fit them and see which is going to work better. I know the ford one will fit, but the dodge one is bigger I think...
Some more pics... fuel tank is done... Most of the exhaust is on, (no 5" tip yet), rebuilt the 273 transfer case with the dodge input shaft, more to come...
Old 11-16-2007, 04:21 PM
beansdiesel
I have a Spearco 6.0 IC, its bigger then the 7.3 or Dodge cooler. The Dodge cooler is longer side to side but shorter I think. I dont think it will fit well at all I would just use the 7.3 cooler for fit cause it should drop right in.
Old 11-17-2007, 10:15 AM
barnbuoy's Avatar
barnbuoy
barnbuoy is offline
anyone ever put one of those in one of these? (like i need another project)
was getting ready to sell it.....hmmmm it's a 1ton with a 7.4 gasser.
  #28
Old 12-03-2007, 01:11 PM
5.9Excursion
Mostly finished, took it for a spin yesterday. Only have one battery installed right now, I haven't made the dual battery tray yet. Here's some more pics...
  #29
Old 12-03-2007, 01:36 PM
MisterCMK's Avatar
MisterCMK
Avid Winter Hater
Looks great man. What are your first impressions?
  #30
Old 12-03-2007, 02:27 PM
5.9Excursion
First impressions... well I drove it very very easy a mile down the road and back to help bring everything up to temp, so I could check fluid levels and top them off. It shifts with authority for sure. I am waiting to hear from ATS to help me with how to setup the transmission controller. I have yet to put all the gauges in before I take it for a real drive. I'll report back my results...
Quick Reply: Excursion V10 swap to 5.9 cummins...
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
