Hey I See You Got A 4.10's With The Ford Trac Lock. Do You Like The Trac Lock? I Got 4.10's But Im Wantin To Put Some Kind Of Posi In Front And Rear. I Have Looked At That One And I Have Looked At a Detroit Locker. I Was Just Wondering How Ya like It Cause the Detroit Is pricey....
Just got it recently so I haven't had much a chance to try it out (only driven on pavement so far). I have however broken the tires loose from the pavement a few times when goosing it and after spinning for a moment they grabbed REAL hard; I'm assuming this was when the trac-lok locked up. So it seems to be working pretty well.
I used to have a short-bed, regular cab, 4x4, which was not available with the extra tank. I replaced the 18 gallon rear tank with a 36 gallon unit I bought from JC Whitney. The tank was only about $200 but I did have to convert my ITR pump to the 2-pump setup with junkyard parts.
Do you have a part number for that tank? I cant find one. would like to get one asap, also will the same sending unit used?
thanks, mbis57
It fits where the original rear tank fits on our OBS trucks. You will need to find a new place to carry your spare, if you still have an under-truck spare.
