aod behind a carb
Old Oct 14, 2007 | 08:48 AM
muscletruck7379's Avatar
muscletruck7379
aod behind a carb
i replaced a c4 with an aod out of a 90 crown vic. i am using a weiand 8011 intake and carter afb carb. in order to get the tv cable to work can i change just the one end at the carb off of a vehicle that had an aod without having to swap the whole cable?
many thanks
Old Oct 14, 2007 | 01:48 PM
rclarke's Avatar
rclarke
Use any way you can to get a throttle input to the transmission and set the idle pressure with a gauge. The lever at the transmission should follow the throttle lever from idle to WOT.
