WANT TO BUY - WIRING HARNESS
I believe you will end up having to piece something together or start checking junkyards
Not sure what you mean by top dollar but I'll look at the junkyards around here for you
The harness on the engine side is the front half of the harness that is everything in front of the bulkhead connector IIRR
The old, carbureted ones may have had a separate alternator harness
A carb'd 87 is a Unicorn IMO and you may never find one
The following users liked this post:
Every 351W was carbureted in ‘87 so it isn’t a unicorn but finding a 36 year old harness will be a challenge.
No
Do you have a part number yet?
If that then maybe I can help
Obsolete parts in CA
You need the part number
Fixing yours most likely the best bet
You will need a real Ford schematic
Good thing is there is not a lot of wires on your carbureted 87
How bad is it?
Can't be much worse than my Boss 302 was when I got it? (Unless it was a burn job)
How bad is it?
JRB64
08-04-2017 10:41 AM
