What ratio gear is best?
Thanks for the reply, i did the calculator, and it said at 70mph, 2200rpms, and 37" tires that the gear ration should be 3.4 Does that sound right?
Guy i talked to that is selling a truck with 37's and 456 gears said he gets about 16-18 mph on the highway with no load. And about 15 mph in the city.
Do you think that is BS?
No it is not BS.
You have to find the sweet spot between too high and too low of an rpm depending on how loaded the engine is going to be most of the time.
Going to be running empty, or at most with a bed full of equipement covered over with a canopy? I would go with 4.10's
Need to tow? Tow heavy? Then gear it lower. But I wouldn't tow with tires that big, you have to take into consideration that the brakes are now working that much harder to stop the truck too.
Your final decision on what gear ratio to use completly depends on what you plan on using the truck for.
best gear calc out there.
http://www.grimmjeeper.com/gears.html
focused on 4x4's but at the bottom it works for street.
what is the transfer case and underdrive for our trucks with that www.grimmjeeper.com webstie?
and for the underdrive, just leave that blank unless you have a klune, or blackbox.
