Replacement engine for 1998 V6
I have a 1996, F150, 5 speed manual, that’s in good shape, except the engine is full of water, due to a blown head gasket. Previous owner stated he rebuilt engine, but it appears he wasn’t much of a mechanic.
What are my options for replacing the engine? It doesn’t really matter to me if it’s a junkyard, rebuilt, reman, or crate engine. Just looking for something to drop in and drive. Not looking for performance engine, but would consider 5.0 if it would bolt up to the bell housing.
Im not in a rush and will probably install it myself. It’s not worth much, just sitting.
Thanks,
John
Thanks,
John
on
The title says '98 while you have '96 in the body of your post, there was no V6 in '96 but there was in '98.
In either case the easiest swap is going to be with another copy of the exact same engine the truck has now, anything else is exponentially more difficult with machanical, wiring, and PCM changes necessary.
The following 2 users liked this post by Conanski:
I guess I’ll look for a reman engine. I wouldn’t take a chance on junkyard engine as old as ‘97-‘00.
I was hoping someone had done a quick and easy swap with a salvage engine from a newer model.
Thanks, again
John
