79 Ranchero Front Suspension Rebuild
Old 10-08-2007, 12:24 PM
79rancher_boy's Avatar
79rancher_boy
79rancher_boy is offline
I was wondering if anyone had any input......
I have a 1979 Ranchero 351m. Lets just say the car just about drives like a boat. You go up and down and roll left and right on every turn and bump. I think it's time for a front end suspension rebuild. I have done lots of work on cars, but suspension is an area that i have never gotten to. Are there any kits out there that would get me just about every part to do the rebuild? Any special tools needed or things i should know?
Old 10-08-2007, 01:34 PM
merlynr's Avatar
merlynr
merlynr is offline
Sounds like new shocks may cure some of your problems.
Old 10-08-2007, 01:50 PM
ShockGuys's Avatar
ShockGuys
ShockGuys is offline
Shocks would be a good place to start.
Old 10-08-2007, 09:26 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,579 Likes on 1,288 Posts
It's operating as designed....
Check Hellwig
http://www.hellwigproducts.com/products/default.asp
They do not list your rig, but see if they can bend one up for you about twice the diameter of the stocker, front and rear.
If you can't get a better bar, get new urethane bushings for what you have. You probably have 1-1 1/2 inches of slop in your bar right now.
Stiffer springs and two shocks per wheel would be next. You're fighting an uphill battle here............
Old 10-09-2007, 02:54 PM
bseberle1's Avatar
bseberle1
bseberle1 is offline
I rebuilt my 77 Ranchero front suspension using the front end rebuild kit from Performance Suspension.
http://www.performancesuspension.com/
Old 10-10-2007, 08:09 AM
Dave Severson's Avatar
Dave Severson
Dave Severson is offline
The Performance Suspension parts are really first rate!!! I've used a number of their kits on rebuilds and found the parts to fit great and work even better, especially the kit with the polyurethene bushings.....
Old 10-10-2007, 08:41 AM
merlynr's Avatar
merlynr
merlynr is offline
I bought a 79 Ranchero 500 in the early 90's for resale and I swear it had a 351W eng. It was not modded in any way, just stock.
Ranchero Stephen
06-30-2012 04:57 AM
lgyee4
01-18-2012 08:46 PM
AstroFab
02-02-2011 08:13 PM
craig1267
11-30-2005 03:23 PM
50J03
10-14-2004 01:47 PM
Quick Reply: 79 Ranchero Front Suspension Rebuild
