mystery 429
Okay...now, where in BC ?
There are tons of speed shops in the Vancouver/Surrey/New West areas.
You can also buy online with MOPAC.
http://www.mopacautosupply.com/
or
Have stuff sent from Calgary/Edmonton/RedDeer,etc
Western Motorsports
http://www.wmsracing.com/
or
Western Motorsports
Shouldn't be too hard or expensive to get something out of Kelowna.
Here are some GV listings.
http://www.gvrd.com/auto_parts/index.html
my friend built my old 429 out of a 70 t-bird. He bought the motor from me for 600 with bad bearings. He put about $9k into it. Dyno proven 713hp at the crank on 105 octane. Bored out to 435. It was nasty. Very sneaky in a long bed pickup. It runs 7.20's in 1/8th mile all motor. In a 76 f-100. It is coooool. The only bad thing is getting about 3 mpg and paying $6/gal for gas.
yep, hp depends on cam and valvetrane. you could go a 545 stroker easily- .030 overbore 4.5" stroke, a nice hydraulic cam like lunati 31604, d3ve's from scotty at rhp- ported and with oversized valves installed, rpm air gap or victor intake, 950 cfm carb, and have an honest 500 horse for around 4000-4500 dollars
#29
what cam you need depends on how you will use it. there are lots of ways to get hp out of a motor without cammin it up. mostly airflow, lots of porting, good headers, intake, carb etc. You can get your 500hp without throwing a huge cam in the motor. The bigger lift and longer duration the less streetable it will become.
#30
but the more cubes the smaller the cam acts. thats why i said the 31604 instead of the 31602... in a 545 the 31604 should be about like a 31601 or 2 in a 460, also lift doesnt matter on streetability- its duration and lobe separation that mainly affect streetability.
