2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
expy from hell lol p0174 p0171
Old 08-23-2008, 09:12 PM
deltasoft's Avatar
deltasoft
deltasoft is offline
Good afternoon All,
Finally i got new cats on my wife's 97 5.4L v8 4x4 expy, however i am getting codes p0174 and p0171 "system too lean on bank 1 and system too lean on bank 2.
I put a new MAF sensor & applied fuel injector cleaner into the tank, however this has not helped at all and engine is still missing...
I changed all 8 spark plugs about 3 weeks ago....
any ideas guys? it's like is loosing power .......and shuts off on me sometimes when i turn AC on.......
Also the pulley tentioner i know is bad cuz is making squicky noises......could that be part of the miss?
Again guys your help is much much appricated thanks a bunch!
Old 08-24-2008, 01:56 AM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
Sometimes the plug comes out of the airbox where the MAF goes. Heard of that causing problems like you describe.
If that isn't it, I would look at a vacuum/air leak as the source of your problem.
Old 08-24-2008, 09:18 AM
Lariat Trucker's Avatar
Lariat Trucker
Lariat Trucker is offline
Sounds like someone used cheap universal cats instead of Car Sound (MagnaFlow) or Imco direct fits. Both of those codes are O2 sensor codes from the exhaust. Might be an exhaust leak at the manifolds but sounds more like either a change in the O2Sensor placement or a light load cheap cat.
Old 08-24-2008, 01:32 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
Those O2s are before the cats. If the cats were not working right, he would get an emissions efficiency code.
Old 08-24-2008, 01:34 PM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
While both of the codes emanate from the forward O2 sensor, it doesn't mean anything about the operation of the cats.
Old 08-24-2008, 05:10 PM
deltasoft's Avatar
deltasoft
bad bad news....it left me stranded this morning with wife n kids......had to get cab ...go get superduty, then go to autozone and buy fuses then drive back home without it luckely shutting off again....
FUSE # 30 below steering wheel on fuse box keeps popping...what can cause that?
service engine light on ....codes p0171 & p0174 .....
wildchildbmx6
1997-2006 Expedition & Navigator
12-08-2008 04:34 PM
armysoldier50
08-31-2008 11:24 AM
50th ann
1997 - 2003 F150
06-23-2008 03:54 AM
hotrod99
03-26-2007 12:28 PM
MrBookworm
01-28-2006 09:47 PM
Quick Reply: expy from hell lol p0174 p0171
