on my 79 there is alot of play in the wheel and I can tell it is the steering box the screw with the nut on top of the box is that an adjustment screw I really don't want to buy a new one
yea I got the front end apart I am doing the brakes ujoints and checking the inner and outer bearings. before I took it all apart with the tires on the ground you can turn the steering shaft by hand and see it turning the steering box without the pitman arm moving.
