Sponsored by: Real Truck
Tow/Haul mode question
Old Sep 26, 2007 | 09:41 AM
redford's Avatar
redford
FTE Leadership Emeritus
Question Tow/Haul mode question
Here's a question I have about Tow/Haul mode on the 5R110W transmission.
First, the transmission isn't a 5 speed, it is a 6 speed. Old stuff, we've covered this before. It skips either 4th or 5th depending on the weather.
On cold engine operation (below 0 degrees) the overdrive clutch is engaged in third gear for a ratio of 1.09 : 1. The transmission will shift directly to sixth from fourth and fifth is skipped. On a warm engine the shift pattern would be 1st, 2nd, 3rd, 5th (direct drive), 6th.
But, I came across this reference in the 2007 Owners Manual:
Tow/Haul feature (5–speed automatic transmission) (if equipped)
To activate, press the transmission control switch (TCS) located on the
gearshift. The TOW/HAUL indicator light will illuminate in the
instrument cluster. The transmission will operate in all gears. Press the
transmission control switch again to deactivate Tow/Haul mode.
Is this saying that if I keep my truck in Tow/Haul mode I will have a 6 speed automatic?
Old Sep 26, 2007 | 03:56 PM
Beerstalker's Avatar
Beerstalker
I think it is just referring to the fact that it doesn't lock out overdrive (6th gear) like the earlier transmissions did when you hit the switch on them. As far as I know it still works as a 5 speed.
Old Sep 26, 2007 | 05:00 PM
bpounds's Avatar
bpounds
I have to agree with beerstalker, because I've counted the shifts and it's only five, in or out of T/H. Plus, Ford is secretive about the 6 gears and I don't think they want the user to ever experience 6 consecutive gears.
Bill
Old Sep 26, 2007 | 09:44 PM
F250tuff's Avatar
F250tuff
I use mine regularly. As the others said, it still shifts through only five gears total.
Old Sep 26, 2007 | 11:59 PM
aldridgec's Avatar
aldridgec
They say that so consumers would know it wasn't an O/D OFF button like before.
Old Sep 27, 2007 | 06:58 AM
redford's Avatar
redford
OK, thanks guys.
Old Sep 27, 2007 | 09:21 AM
bpounds's Avatar
bpounds
As I vaguely recall the ratios, 3 and 4 are so close together that if it shifted to both of them you would probably think something was wrong with the transmission. It would feel too much like a slip.
Bill
Old Sep 27, 2007 | 12:51 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Actually it's 4th and 5th that are really close. 4th is 1.09:1 and 5th is 1:1. Sixth is 0.71:1.
Old Sep 27, 2007 | 01:02 PM
bpounds's Avatar
bpounds
Yea, I thought I might have that wrong. Too lazy to look it up.
But you can see my point about those two ratios.
Bill
DR Buck
Oct 16, 2016 10:12 AM
07EXPYEL
Nov 10, 2008 11:31 PM
tinytrixie
Feb 21, 2005 10:41 PM
Paclik
Sep 9, 2004 10:10 PM
jarmbrester
Oct 13, 2003 08:55 PM
