Yet another charging problem!
Old Sep 25, 2007 | 07:18 PM
trike1946's Avatar
trike1946
Question Yet another charging problem!
My 96 is acting up again. I have been working 7 days a week and usually late for a few months, so I can't even get the time to fix things right. I just duct tape things together and keep going. I had to replace my alternator a few months ago, and it fried the maxi fuse with it. It has the ambulance package. It has been working fine until last week. The amp light came on and the gauge (factory) shows it overcharging a bit and sometines not at all. It goes up to about 15.2. I used a meter. I pulled the alternator out in the middle of the night and took it to the place that rebuilt it when they opened. They tested it in front of me and it was fine. They said sometimes the plug goes bad and it causes the problem. So I replaced it and put it back in. The amp light is still on and it is still overcharging. My question is could it be one of the two wires on the plug causing the problem? One is yellow with a white stripe, and the other is green with a red stripe. I have no idea where they go. Or any other ideas. I am driving about an hour each way to the job and would hate to break down. Thanks for any help. The alternator is 215 amps.
Old Sep 25, 2007 | 09:12 PM
SrqScion's Avatar
SrqScion
With the high output alt you should have an external voltage regulator... not sure of the location on the van but that is what i would guess. the regular alts have it built into them, this is not true on the 215 amp alts. Should be your probelm, pick one up and throw it in
Old Sep 26, 2007 | 05:12 AM
trike1946's Avatar
trike1946
Thanks for the reply. The regulator on this one is internal. That is what went bad on it before, and that is what I also was thinking when I started having trouble. But when they tested it, it was working fine. They showed me while it was being tested that if the plug came loose it would still charge but would be high and low like it is doing. That is why I wanted to trace the 2 wires and see if that is the problem. But with a van it is almost impossible, so I am looking for a wiring diagram. Can't find one though.
Old Sep 26, 2007 | 06:22 AM
Cuda_jim's Avatar
Cuda_jim
Bob, I remember the last time you had trouble:
https://www.ford-trucks.com/forums/6...-question.html
Here's the schematic for your truck I think. The Light green w/Red tracer wire is going to the volt meter in the dash. Someone just recently had trouble with that wire getting loose causing an intermitant charge/discharge.
I see you have an additional Volt meter? Where did you tap that into?
Also, Did you check all the connections you see in the schematic? Batteries, starter, solenoid ect ect.
Old Sep 27, 2007 | 06:09 AM
trike1946's Avatar
trike1946
Hi Jim. I didn't know where the green wire went. The volt meter was just the hand held type. I will check all the connections and look at the dash gauge. Thanks, I'll report back.
Old Oct 23, 2007 | 06:18 PM
trike1946's Avatar
trike1946
Jim you get another A+. I finally had time to pull the dash apart and the wire going to the gauge was loose. Problem solved. This is still my busy season so I had to just drive with the amp light on until i had time to look at it. Thanks very much.
Old Oct 23, 2007 | 06:22 PM
Cuda_jim's Avatar
Cuda_jim
Thanks Bob, Glad you got it. the credit goes to FTE, I just read 'em. Remembering...that's different story. Crap shoot at best
at38b
Oct 26, 2013 09:26 PM
Nyxlee
Jan 26, 2011 09:07 AM
rdct
Electrical Systems/Wiring
Mar 19, 2010 07:56 AM
Extreme1220
Jul 29, 2008 05:12 PM
vaman4215
May 27, 2007 06:31 AM
