Lock / Unlock Confirmation
10-29-2007, 03:36 PM
on
All
My 07 expedition sounds the horn and flashes the lights when I lock it with the keyfob but does nothing when I unlock, is this correct or can this be programmed to do the same thing on unlock. I know on previous expeditions this could be programmed.
When I unlock with the key pad on the door at least the lights come on
Please let me know
Thanks
WC
10-29-2007, 03:57 PM
My 07 the lights come on when you unlock. I know you can set the delay time for the lights to go out when you lock but I don't know about the unlock.
10-29-2007, 04:26 PM
on
this may be a BCM(body control module) setting that the dealer can do for you but it requires equipment they have and we would not spend money on.
10-29-2007, 04:29 PM
on
Thats the problem is that my dealer is saying they don't think you can do it which sounds kid of crazy considering it chirps on lock but does absolutely nothing on unlock. mine is not a limited so don't know about how much I can set myself and how much needs to be programmed. I thought this would be standard programming options
10-29-2007, 05:38 PM
Mine only honks on lock when I hit the button twice. Otherwise it just flashes the lights for lock and leaves them on for a few seconds on unlock.
Do you have an alarm installed?
10-29-2007, 06:01 PM
on
I would think the BCM would be the same on all models BUT...BUT...I am getting quite an eye opener on what Ford does and does not per model and per year.
10-29-2007, 06:33 PM
on
My 07 locks all doors first click lights flash then second click horn beeps lights flash.
First click unlock, just the drivers door. second click unlocks all doors, no beep at all, lights come on at night only when doing this.
07 EB non EL 4x4
10-29-2007, 06:43 PM
on
While we are talking about the key fob. Is there a battery in this fob? And if so can it be replaced? I would think sooner or later the battery would run down. Just wondered.
10-29-2007, 06:44 PM
on
Mine does the same as your Newton007. So can we do more? I think a trip to the dealer is the only way to know. I just may do this if I have time.
10-29-2007, 06:47 PM
Yes, the battery can be replaced. You pry the fob apart with a dime or such. They last about 18 to 36 month IME.
rikosintie
11-10-2016 06:29 AM
mmenzies
02-26-2015 06:17 PM
fcctobe1
1997-2006 Expedition & Navigator
12-21-2012 03:50 PM
CaptainD_1214
11-08-2012 10:52 AM
Harvick
1999 to 2016 Super Duty
04-08-2009 03:29 PM
change,
chirp,
expedition,
ford,
honk,
honks,
horn,
lincoln,
lock,
navigator,
unlock
