lifting a 2wd
Old Sep 18, 2007 | 10:37 PM
mrwrench's Avatar
mrwrench
lifting a 2wd
How to lift or level the front of a 2002 powestroke single cab?
Old Sep 19, 2007 | 02:27 AM
Mach1's Avatar
Mach1
I like lowering the stance on a 2WD, so I lower the rear a couple of inches...
But you wanted to know how to raise the front, It can be done with spacers under the front springs, or longer front springs, or relocation of the spring hangers. It can even be done with the inverted dropped I-beam axles.
Just depends how much you want to spend, or how in depth you want to get..
Having it aligned AFTER the lifting is priceless, better have a good alignment guy.
Good Luck
Old Sep 19, 2007 | 09:08 AM
mrwrench's Avatar
mrwrench
thanks , can you expand on the concept of inverted dropped I beam axles?
Old Sep 19, 2007 | 03:20 PM
Mach1's Avatar
Mach1
I guess its like the dropped axles, rather though the opposite direction. This is going to be the most expensive way to raise the truck, I would do the lift by spring spacing, its a safe, economical way to approach the problem.
Old Sep 19, 2007 | 05:28 PM
mrwrench's Avatar
mrwrench
Mach1
thank a lot for the help
juan
Old Sep 19, 2007 | 05:49 PM
Izzy351's Avatar
Izzy351
Out of curiosity, how much higher are you going? I was thinking about doing the same thing to level it out a bit and give it a little meaner look.
Joe
Old Sep 19, 2007 | 06:01 PM
mrwrench's Avatar
mrwrench
maybe 2 or 4 inches . I don't want the dropped nose in 2wd.
by the way, do you know if the 2005 front axle with spring suspension can fit in a 2wd?
the spring housing looks very similar!
Old Sep 19, 2007 | 06:57 PM
Mach1's Avatar
Mach1
The 4X4 front axle can be fit in to place. A lot of work though. I still say go with a spring spacer above the spring..Although compressing/uncompressing it will be a challege.
Old Sep 20, 2007 | 08:32 AM
99SevenPoint3's Avatar
99SevenPoint3
if not mistaken the spring spacer gives u a good 3" lift if more needed i belive u have to move on to a larger spring ... might want to double check that ...oh and if not mistaken their is a rubber type spacer and a metal type ...ive always seen the rubber one used i figure it would be less noise
Old Sep 20, 2007 | 11:20 AM
mrwrench's Avatar
mrwrench
whee can I get the larger spring?
thanks a lot
