lifter noise and oil passage problem
Old 09-25-2007, 10:00 AM
Jag Red 54's Avatar
Jag Red 54
Jag Red 54 is offline
Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.
Bill, adjusting the valves is not hard, but it is difficult to describe in detail how to do it. Have you ever adjusted valves on any engine? You must have each piston at top dead center as you adjust its valves. Without having someone there to help make sure its done right, it might be a good idea to have a reputeable shop do it. Too loose is noisy. Too tight is a burned valve. Good luck, Jag
Old 09-25-2007, 03:52 PM
kooper909's Avatar
kooper909
kooper909 is offline
kooper909 is starting off with a positive reputation.
You can always adjust the valve clearance while it's running ... but then again on a V8, you're more likely to get oil everywhere doing that.
beartracks
Oil & Lubrication
11-04-2011 12:09 PM
ronjon95
19
09-02-2010 06:03 AM
Hunter8354
1999 to 2016 Super Duty
02-12-2009 10:51 PM
DSMMH
02-06-2008 02:20 PM
BUZZer67
03-06-2007 04:36 PM
Quick Reply: lifter noise and oil passage problem
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
