390 Build
390 Build
Ok Guys and Gals, I'm building an engine for my 75 Highboy and I want your opinion. I have about a $2500 budget. This is what I plan on putting into my motor. I want you guys to tell me what I can do to make it better and if one of my parts is bad or to big or to low tell me what to exchange it for. I also need to know what kind of cam would be the best for this build. I want a choppy idle with low end torque.
Parts List
Cam & Lifters ----- Comp Duration 278/296, Lift .506/.493, Lobe Separation 107
Carburetor ----- Edelbrock 4 BBL 650 CFM
Intake Manifold ----- Edelbrock Dual Plane
Distributor ----- PerTronix Hall Effect, Mechanical Advance, HEI/Male Cap
Rings & Bearings ----- Sealed Power, Moly Rings, Tri-Metal Bearings
Plug Wires ----- Moroso Wires 8.5mm
Dress-up ----- Edelbrock Chrome Stuff
Parts List
Parts List
Parts List
Serving suggestion:
Speed-Pro Forged Pistons ZL2446F30 - SummitRacing.com
About 9.5 CR.
Parts List
Pertronic is cool, but factory Duraspark is cheaper and just as effective.
Spend as much as you can on getting the shortblock perfect. It's only a thing to swap out the top end at a later date.
What are your plans for the truck , daily driver ,lowes runs,work ,hauling or just a weekend warrior ?
this is the deciding factor for your cam and compression ratio choices .
+ 1 on not getting the dress up spend your budget on go fast goodies you can add the chrome stuff later .
oh and keep the duraspark , you wont se any performance gain switching to pertronixs
a good "budget" piston choice . i have these in my 390
Speed-Pro Hypereutectic Pistons ZH395P - SummitRacing.com
Previous posts are right also about intended use. If the OP wants a hot rod motor, the 9.5 and certainly the 10/10.5 pistons are the way to go. If he is going to pull max loads up mountain passes, maybe Ford was right with the 8is compression in stock motors.
