Oil pan ?
Old Sep 17, 2007 | 01:13 AM
Ak68F250's Avatar
Ak68F250
Oil pan ?
Which one of these oil pans would be the better choice.
Mildon 4x4 oil pan #30570
Or
Morso oil pan Off road #20612
Trying to replace my oil in a brand new motor going into a stock 1997 F350 4x4
with 460 in it.
Thanks
Old Sep 17, 2007 | 11:12 PM
mark a.'s Avatar
mark a.
If you have a automatic trans I probably wouldn't use either of them. With most rear sump aftermarket pans you have no way to get to the torque converter studs.These pans butt right up against the bell housing making it impossible to get to the studs. Summit or Jeggs sell a stock replacement pan kit that has everything, dipstick & tube, main stud, pick up tube & pan, for a lot cheeper then either of those pans.
Old Sep 17, 2007 | 11:19 PM
monsterbaby's Avatar
monsterbaby
mark you can get to the TC studs through the hole for the starter, I run the milidon rear sump pan on mine and like it.
Old Sep 18, 2007 | 10:13 AM
mark a.'s Avatar
mark a.
I think you would have to trim out the hole some to get a socket on the nuts ? But at any rate it would be a real pain to get it lined up working through the starter hole. I had a Milodon 4x4 pan and ended up getting rid of it for that reason + I didn't see the need for spending the extra money to run 9 qts of oil.
Old Sep 18, 2007 | 10:55 AM
trinogt's Avatar
trinogt
I didn't think one could even SEE the nuts for the TC through the starter hole, let alone take them off or put them on... For that matter, I don't remember seeing the TC at all through the starter hole?? I guess it's been too long for me!
Old Sep 18, 2007 | 11:07 AM
mcdonaldm's Avatar
mcdonaldm
you can get at the TC nuts thru the starter hole, but it is not a fun job as it is not a straight shot to the nut with a socket and extension. i had to do it twice already.
what i ended up doing is cutting the plate that goes between the engine and tranny to make an access door to get to the TC nuts. then i just drilled and tapped the bellhousing to hold the access door in place.
rgds
Miike
Old Sep 18, 2007 | 09:01 PM
Ak68F250's Avatar
Ak68F250
Thanks everybody with all the info i will go with the stock pan again. Now i just need to order the clutch and new flywheel to get my truck back up and running with new motor.
Old Sep 19, 2007 | 06:42 AM
mr clutch's Avatar
mr clutch
are you looking for a stock or hd clutch? i have both in stock along with the factory flywheel. give me a call
Old Sep 19, 2007 | 07:35 AM
trinogt's Avatar
trinogt
It's cool to have you guys in these forums with advice and parts ready to go!
I know advice is free; But are the parts cheap?
Old Sep 19, 2007 | 07:42 AM
mr clutch's Avatar
mr clutch
give me a call so i can verify the year and application but the flywheel is around 150 and the kit is around 260 for hd and the stock about 220.
fancyvern
26
Sep 23, 2019 09:16 PM
NC82F250
Jul 12, 2017 10:30 AM
bigcrunch
Aug 31, 2016 09:16 AM
peka
Aug 26, 2015 01:51 PM
fordracer08
Jun 15, 2011 09:15 PM
