1978 - 1996 Big Bronco
Rear Window
Old Sep 14, 2007 | 08:12 AM
martijef's Avatar
martijef
Rear Window
Just Finished Checking Out Rear Window Motor.bad Wiring From Motor To Connector.there Was A Black L Shaped Piece Of Plastic ?fusible Link Or Something? This Is Where Wiring Was Bad. Just Bypassed This And Motor Is Working Fine. I Almost Missed This. Just Thought This Might Help Someone. (85 Bronco)IF THIS IS A FUSIBLE LINK YOU MAY WANT TO AD ANOTHER ONE JUST IN CASE.
Old Aug 2, 2008 | 05:07 PM
axbrya's Avatar
axbrya
Was the fusible link from the connector to the motor or before the connector?
Old Sep 1, 2008 | 09:57 PM
yoyobronco's Avatar
yoyobronco
i ave the same problem with mine thank's for the tip's that will help
