Hi guys and gals, i just picked up a motor i was told it was a 390 ,but after checking i found out it was a 360 .But anyway could you tell me something about it:-(
thanks , marvin , manafold 5a6 c5ae9425g
heads, c4ae 3090
carb,c5af av 4 4me
ps, is this 4 b manafold and carb any good to use if it checks out to be good.
The head numbers are probably C4AE 6090 G, The "G" on the end may be partly covered up by a screwhead impression. These are very good early-style FE heads with the tall intake ports, "D" style combustion chamber and the raised exhaust ports. Lots of people do a little port work with these heads and stick in CJ valves. Don't give 'em away!
I'll try to look up the carb. number when I get home.
