Check Engine Light On
Old Sep 9, 2007 | 04:16 PM
DBANDGB's Avatar
DBANDGB
This Is A Chalange;;i Bought A New Ground Cable From Ford. Installed On My 89 F-150 With A 5.8...started Up Fine, Then Check Engine Light Came On & Stays On. During Instalation Of Ground Cable I Could See O/2 Wires Being Moved.. They Were Bad So I Installed New O/2 Sensor.. Had Battery Off Over Night..started Truck, Check Engine Light Came On & Stays On, Wont Idle Good, & Go To Put It In Dr. It Stalls...any One Have A Guess??? Thanks Gary (ps It Ran Good With The Bad 0/2 Sensor)
Old Sep 9, 2007 | 05:04 PM
radialarm's Avatar
radialarm
With the CEL on it is in limp home mode thats why it wont drive right, You will have to pull the codes and fix whats wrong. This website has a lot of info.www.fordfuelinjection.com
Old Sep 9, 2007 | 05:05 PM
kcb37's Avatar
kcb37
Make sure your ground made a good connection on both ends.
