Reverse Noise
Old Sep 7, 2007 | 04:45 PM
BIGFISH70's Avatar
BIGFISH70
Reverse Noise
I have an 07 F150 4.6 and when I put it in reverse it makes a hummimg sound and the truck vibrates, any ideas. Thanks for the help.
Old Sep 7, 2007 | 06:36 PM
SUPERDUTY_untouchabl's Avatar
Does it do it as your backing up? Mine makes a whining noise when backing up but it dont vibrate the whole truck.
Old Sep 7, 2007 | 08:40 PM
BIGFISH70's Avatar
BIGFISH70
it just does it when backing up, its not the normal noise that you get when backing. Its more like a chattering noise like when you turn drums on a lathe.
Old Sep 7, 2007 | 11:02 PM
VFR_Man's Avatar
VFR_Man
Ahhh, yes. Mine does it too once in awhile if it's been sitting for awhile in humid weather or has been washed and doesn't get driven immediately. I think it's just the rear brake pads clattering on rotor corrosion since it goes away once the brakes have been used enough to clean off the rotors again.
Old Sep 8, 2007 | 01:33 PM
BIGFISH70's Avatar
BIGFISH70
That sounds good, thanks for all the help.
Old Sep 8, 2007 | 07:12 PM
Wilber15's Avatar
Wilber15
Pull the rotors off and see if the rear e-brake shoes have seperated.... problem seen alot at the dealership. the e-brake shoe linings tend to seperated from the shoe and chatter while in reverse.
