Tow w/overdrive on or off?
I keep gettin mixed reviews from people, is it ok to click the overdrive back on when I get up to cruising speed on the highway? I have an '03 F250 SD Lariat FX4 w/ 5.4L V8. I just got the truck a couple months ago and haven't had to tow with it yet cuz i'm in the process of changing some things up on my racecar, but it will be running again soon and I also told a buddy i'd go pick up his boat for him this weekend, so I just wanted to get this settled for sure of what's right. Thanks for any help guys!! Also, i've been told that going cruising over 70 with a trailer on the back is really bad for the trans, is this a myth or what (I had a problem with the trans in my '04 F150 Lariat I had before this truck after only 40,000 and these are things people were tellin me, cuz I used to click the o/d back on when I reached cruising speed and towed between 80 - 90 most of the time on long highway trips)?
I generally leave it on unless im in the hills or mountains, or if it keeps shifting back and forth. I dont know how a gas tows, but to tow at 80 to 90 in my pickup you have no choice but to be in OD. The only thing the speed has an affect on i believe is tranny temp. I tow all the time with the cruise on 80 to 85 and have over 150000 miles on my stock tranny.
You can tow all day long in O/D and it won't hurt the trans. What you have to watch for is gear hunting. If it's shifting in and out of O/D, that's adding lots of heat which will reduce the tranny life. In that situation is when you lock out O/D until you get to flat ground and an even speed.
Thanks guys, that's what I was hoping to hear! Guess I must've just had a turd in my '04 150, cuz we got that truck at 28,000 miles and at 46,000 the trans went out on it, lost overdrive and reverse and had to pay $1500 to rebuild the trans cuz it was out of warranty cuz the place we bought it from told us it had an extended warranty, but we came to find out they never transferred it over from the previous owner or some bull**** and basically we got screwed and had to pay to get the tranny fixed.
Originally Posted by redford
Check the local laws before deciding you can tow at 70 or 80 MPH. A lot of states have special speed limits for any vehicle towing a trailer.
In Illinois, it is 55 MPH, although the State Police will usually let you get away with 60 MPH if conditions are good.
Last I checked, anywhere 80 or 90 mph is illegal....
The trans in the f150 probably had issues because it was a 4r70w. They use a band for od, which is probably why reverse went out too. The bands can't hold much power or load, so no od on them.
However, the 4r100, uses a large clutch at the front of the transmission so towing in OD is ok. Pretty much the only reason to lock it out is if you notice heat, or it's hunting on hills.
Have you ever started off in OD from a full stop? No, of course not, at least not in an automatic. Running in OD with a "non-normal" load and especially at HIGH speed is a lot like having a stick shift and trying to start off in an inappropriately high gear ratio.
Don't, DO NOT.
And yes, your engine may be able to produce enough torque in a "minus" gear ratio (the transaxle output shaft turning FASTER then the engine), but the torque converter lock up clutch was not designed for such abuse. Basically it was designed to operate in the torque range wherein the engine would provide the best FE under NORMAL operating conditions.
Don't, DO NOT.
Don't, DO NOT.
Don't, DO NOT.
Originally Posted by jomac11
Driving across Illinois at night, with a trailer is very dangerous. Driving that slow, I almost fell asleep...
Don't, DO NOT.
Don't, DO NOT.
Don't, DO NOT.
Don't, DO NOT.
