6.9 or 7.3 turbo in a 70s model f250
Originally Posted by bigbubba87
which would be better a 5spd with say 3.55s or a c6 with gearvendors od?
Can anyone link him to that?
Thanks,
davE350
i have done it, the only real problem i had was the turbo up pipe and the down pipe not having enough clearance, now that would not be a problem if you go with a NA motor, but if not, i just had to cut the firewall out, and bring it in to make everything work/fit! and this was all a lot easier since i had a a complete donor truck, i suggest you do the same, let me know if you have any questions!
ill try to look for some more pix of it later!
[QUOTE=1967 Turbo 6.9]As it happens I'm putting a Bank's Turbo 6.9 in a 67 F250. I updated the chassis by using a 78 cab&chassis frame ( narrower behind the cab)
I opted to not move the engine forward and modified the firewall to clear the down pipe as I may need the room to put the 90 model radiator in front.
I've got a long way to go right now repairing rust is taking My time. It should go fast over the next few week's
http://rides.webshots.com/album/559112963rCSgGX[/QUOTE]
That is one sweet truck! nice job.
-Lance
-Lance
#29
My Webshots username name is gypsumks You can do a search for that or try this link
#30
1967,
Wow! What at tremendous amount of work. Other than the cab mounts, not very many major rust issues, & you could have got away with patching them.
Did you have very much help? Taking all those trucks apart & the sling & all, it would have been nice to have had some extra hands around.
Thanks for taking the extra time to repost the website. Great job.
davE350
davE350
