4x4 control module (4x4 flash problem)
#46
#50
#51
#53
The 4x4 Control Module in my '02 Explorer also needs replacing. I know the part number to buy and plan on doing so very soon.
I'd like to replace the CM myself, and am trying to do a 'run-through' of the removal of the existing CM. I've identified it behind the glove box and can remove the front screw keeping it in place. However, 2 questions:
1) Any tips on getting to the rear screw? It seems totally blocked.
2) I am having a lot of trouble removing the 2 wiring harnesses from the CM. I've tried (gently) pressing the tab on the harness and pulling to remove, but it simply won't budge. What am I missing?
Many thanks.
Many thanks.
#54
#55
Replaced the 4x4 cm last night. The easiest thing to do was to remove the black screw that held on the bracket. Once I removed that (there was only 1 easily accessible screw holding the bracket on) the module was easily removed from the bracket.
A question: Since the current school of thought is that an electrical surge - most likely from a battery replacement or detachment/reattachment - caused the old module to break, then should I unplug the new module whenever the battery is disconnected? Or are the new modules not supposed to succumb to the same problem?
#56
This is the first I've heard of a surge causing the prob (just assumed crappy ford electronics was the culprit). Kind of makes since... anyone else have some info on this??
#57
4x4 Control Module
I just replaced my 4x4 control module on my 2002 Ford Explorer. I did not think that it was the 4X4 module since the 4X4 LOW icon (on the instrument panel) ran through the normal bulb check. My understanding is that the 4X4 Control Module is responsible for executing the bulb check. I found out that the modules was bad by hooking up a DTC tool to communicate with the module and the module did not reply. After I replaced the module I noticed that there is an additional 4x4 HIGH icon on the instrument panel that turned on and off after key-on. The reason this bit of information is interesting is that if the module is bad, the 4X4 LOW icon still runs through the bulb check (even with the module missing...CRAZY) but there is no bulb check for the 4X4 HIGH icon. If you cycle the ignition and you do not see the 4X4 HIGH icon cycle through the bulb check you should suspect the 4X4 Control Module or the lamp behind the 4X4 HIGH icon. Just a note, you can get these modules cheap through your local junk yard. I bought mine for $50 (Ford charges over $300 for one) and it works perfectly. Just get the code off of the module and call you Junk Yard. The last 2 digits on the code is a sequence "number" (from what I understand) so you want to get at least the sequence # that you currently have or later. My sequence code was AG and I replaced it with and AH module and everything works great.
#58
#59
Appreciated all of the posted knowledge here, so I thought I'd join and add a bit.
Long story short: 4WD out, blinking light. Controller was replaced under warrantee years ago, so I figured it was the culprit again. $180 from directfordparts.com. Good service, easy replacement (take the glove box door off, it's easier that way) but still no 4WD. Bummer for me.
Went to take the transfer case shifter motor apart and noticed that ground wire was corroded off after dissasembly. Cleaned up, crimped on a new connector and I'm back spinning all 4 wheels. Just another place for folks to look. Best of luck to everyone.
By the way, send a note if you're interested in a control unit for an '02 Explorer...
#60
2003 Explorer XLT Auto 4WD
I just found the time (and enough snow) to replace the 4x4 CM. I got the part from Silver State Ford Parts (Formerly DIRECTFORDPARTS.COM)Genuine Ford Truck Parts Lincoln Mercury Parts OEM Ford Parts and Accessories for $165.00 (email them with the VIN and they will tell you which one you need. Their response was fast and they were wonderful) It was an easy change out (for my husband with me watching). The 4x4CM looks like a large black Ez-Pass up under the left side of the glove box. Disconnect the negative battery cable (make sure you unlock the doors first, LOL) Drop the glove box (squeeze in the sides and it comes down) and remove the one bolt, that you can see, on the bracket (i think it took a 9/32 socket), remove the screw that holds the CM to the bracket then remove the plugs (one was more difficult than the other). reverse the process to put it back together. It took my husband about 10 minutes in 9 degree weather. I drove it like crazy up my neighbors drive way and around their backyard and it worked fine. I have had no problem with the 4W Low.
One question: I noticed that when I hit some ice the 4W High light flashed and then went out. It still seemed to by in 4WD, though. When I turned the car off and then back on the 4x4 High light was on and the 4WD worked. I pushed the Auto button and the light went out. Pushed the 4W High button and the light came on and it worked. Is this just the function of the Auto 4WD?
Thanks
Thanks
