High miles on a 460 - Page 2 - Ford Truck Enthusiasts Forums
High miles on a 460
Old 08-29-2007, 12:17 PM
_red rocket_'s Avatar
_red rocket_
_red rocket_ is offline
_red rocket_ is gaining momentum as a positive member of FTE._red rocket_ is gaining momentum as a positive member of FTE.
Nice to hear that people are so pleased with the 460 since I just recently purchased a '94 250 HD with that powerplant. Any helpful information anyone can provide on the E4OD? I have tried to do some searching on this forum and have come across some posts that can get one worried about the E4OD. I am sure though that this forum will see a lot more bad comments on the E4OD than good as the common "no news is good news" seems relevant.
Glad I bought my 94 F250 HD with the 460 as I feel it will provide many years to come. It is not my daily driver though, good for that since it does NOT sip gas
Cheers...
Old 08-29-2007, 12:50 PM
Renner's Avatar
Renner
Renner is offline
Renner is starting off with a positive reputation.
I really don't want to comment on the E40D in mine other than the fact that it just hangs under the truck and does its thing. I have more trouble with the selector on the transfer case sticking (needs a grease zerk added in a strategic spot). We used to haul hay on a 32ft gooseneck with the truck (previously towed by a 1 ton Chevy...that ate transmissions left & right, a 1976 GMC 3 Ton....beastly beast of a cabover with no critter comforts at all and finally an 83 F350 Dually with the big international diesel. Selling that one was a mistake...but it didn't do as well in the sandy fields as the 4x4, much more comfortable road truck though)
Old 08-29-2007, 05:20 PM
timberon94f350
timberon94f350 is offline
timberon94f350 is starting off with a positive reputation.
That ain't saying much. My old man has a Hemi & it has less power & worse gas mileage than my 460.
Old 08-29-2007, 06:41 PM
SteveBricks's Avatar
SteveBricks
SteveBricks is online now
***** Emeritus
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
Keep the trans. fluid clean, maybe ADD a trans cooler. Then hope that good fortune follows you. (I don't know if you want to hear that from me - I'm on my 3rd trans).
Old 08-29-2007, 11:38 PM
grizz3000's Avatar
grizz3000
grizz3000 is offline
grizz3000 is starting off with a positive reputation.
I'm nursing a 89 F250 460, 4x4. C6 auto, back to health. It has 155,000+ (speedo and odom were broke when I bought it, but I fixed it)
Just got done fiixing the mechanical oil sending unit as well as the lower intake manifold gasket (talk about leaks, yikes). I did the rear seal last december, but apparently I should have followed the rubber oil pan gasket advice. She's leaking like a screen door right now up top back by the bell housing. I put a high-flow Cat and Cat-back exhaust on it too which has increased my MPG (noticeable difference but I haven't calculated the difference). I'm sure the original OEM Cat and OEM muffler were stuffed with crap. Tranmission filter/fluid as well as rear diff fluid is next. I just re-installed a Subaru engine so I'm getting that POS back on the road first.
What fluid exactly should I put in the rear diff? This will be my first rear diff fluid change I've ever done.
Old 03-23-2014, 06:56 PM
rolley76
rolley76 is offline
rolley76 is starting off with a positive reputation.
460 miles 230k
Originally Posted by KRB View Post
How many miles can I expect out of a 96 f250 with a 460??? I have 93,000 right now and it seems like the day I bought it. I would hope it could continue towing until 150,000. Anybody experience high miles on this old dependable engine??
I have 230k on org equipment 460
Old 03-23-2014, 06:59 PM
Oscello's Avatar
Oscello
Oscello is offline
Oscello is gaining momentum as a positive member of FTE.Oscello is gaining momentum as a positive member of FTE.
The one I just bought has 260k
stdun
37
02-08-2018 07:43 PM
fordatic
10-31-2016 07:33 AM
brnfish
04-19-2016 04:51 AM
bustacap
1999 to 2016 Super Duty
03-30-2016 09:38 PM
moparmusclecars
05-01-2014 06:31 PM
Quick Reply: High miles on a 460
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
