Kentucky Chapter Join Chapter, Leader: SideWinder4.9l
safety
Old 08-29-2007, 11:55 AM
lightstar's Avatar
lightstar
lightstar is offline
safety
I have a 351w with a c4 trans. truck starts in any gear..what do i do to fix
Old 08-31-2007, 09:16 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
You need to wire in a neutral safety switch. Some are on the side of the trans betwen the linkage and housing.
Old 09-02-2007, 10:31 AM
lightstar's Avatar
lightstar
found the switch..3 wires hanging there ..witch wire to where. thank you
Old 09-06-2007, 09:34 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
I'll look thru my manual and see if it gives the color codes. Only 3 wires? I figured 4. 2 for the start circuit ans 2 for the back-up lights.
The easiest way is with an ohm meter. Pick one wire and check the other 2 while in park. If you have continuity between 2, then put the shifter in R or Drive. If you lose continuity, then these 2 are the neutral safety wires.
Old 09-08-2007, 09:55 PM
lightstar's Avatar
lightstar
thank you..soon as weather cools a little I'll go out and check/fix.
Stinkweed14
6.4L Power Stroke Diesel
02-18-2012 11:00 PM
jerseybmc
1997 - 2003 F150
03-09-2010 07:38 AM
HookedOnFuel
34
06-08-2008 08:09 AM
Mike W
24
09-12-2003 10:01 PM
motobub
User Gallery & Picture Display
01-09-2003 01:16 PM
Quick Reply: safety
