Sponsored by: Real Truck
New Fender Badges
Old Aug 26, 2007 | 05:14 PM
nut1605's Avatar
nut1605
New Fender Badges
The black paint on the passenger side fender badge on my truck has started to peel, so I am looking at going with some "custom" badges from "billet badges". Does anybody have these on their trucks? Are they worth the money? Do they stick well on the fender or will they fall off after a while? I just want to make sure they are worth it before I go fork out over $100.00 for something I can get replaced for free. Thanks!
Old Aug 26, 2007 | 05:45 PM
CounterMaker's Avatar
CounterMaker
just to let ypou know, those peeling badges are under warranty and will be replaced at the dealer
Old Aug 26, 2007 | 05:47 PM
nut1605's Avatar
nut1605
I know, thats why I said "I just want to make sure they are worth it before I go fork out over $100.00 for something I can get replaced for free"
Old Aug 26, 2007 | 05:49 PM
CounterMaker
i just looked at their site and those look sweet...can you have them put whatever you want on there?
Old Aug 26, 2007 | 05:50 PM
nut1605's Avatar
nut1605
As far as I know, yes. Not quite sure what I wanna do though...any suggestions from anybody?
Old Aug 26, 2007 | 06:41 PM
riggz's Avatar
riggz
Theres a few members here who have them. Storm has em on his truck. I'm looking at getting some in black soon.
Old Aug 27, 2007 | 03:33 AM
mcjones44us's Avatar
mcjones44us
I've got them. Great quality. They're stuck permanently on my truck. They've been there for nearly 2 years now.
Old Aug 27, 2007 | 06:32 AM
mastercaster's Avatar
mastercaster
i got my replacements from the site below. went with all chrome, all the way around the truck. the only problem with having ford replace them is you get the same crap put back on. also, i am not taking my truck into the dealer to wait for them to replace them. my truck works for me, so it's usually to my advantage to just pay for things that small out of pocket (unfortunatly).
http://www.fordemblem.com/
Old Aug 27, 2007 | 07:02 AM
kenneBF250V10's Avatar
kenneBF250V10
I have them on my truck. They've been on for over two years now and they still look like they did the day I put them on. Like the names says though, "billet" badges, they will require some polishing if you live in an area that uses salt on the roads in the winter. A little Mothers aluminum polish takes care of that though. The quality is top-notch and they stick very well, well enough that you better test fit for location before you peel the backing off, because once it's stuck on, it's not coming off. Here are some pics of the badges I had made.
Old Aug 27, 2007 | 07:32 AM
tex25025's Avatar
tex25025
I got them on my truck it did hurt a little bit to get those king ranch badges off. Now if you do them like I did as part of a business well then that's considered an ad for the business and you should be able to write that off. I would still do it even if it was for non-business badges, it does draw alot of attention.
Old Aug 27, 2007 | 09:06 AM
riggz's Avatar
riggz
nice raised pinky fingers
Old Aug 27, 2007 | 09:27 AM
pf350's Avatar
pf350
yes hahahahahahaha
Old Aug 27, 2007 | 10:26 AM
nut1605's Avatar
nut1605
Thanks for the replies guys, I think I will try to come up with a design for some new badges. How easy are the old ones to get off? I've read to use fishing line, WD-40, and heat to "cut" the glue, and then pull them off. How do you get the rest of the glue off the paint once the badge is off? Thanks again!
Old Aug 27, 2007 | 10:34 AM
tex25025's Avatar
tex25025
Heat them with a hair dryer, then use a fishing line to cut into the glue, carefully pull them off(I was able to get them off so I can put them back on when I get ready to sell the truck) and then use goof off or some orange based cleaner to wipe off the residue from the truck and the old badges, wipe the cleaner off allow to dry and then put the new badges on.
Old Aug 27, 2007 | 11:06 AM
kenneBF250V10
Thanks for noticing!
