22 mpg w. oversize valves!!
Old 02-05-2011, 07:02 PM
F-250 restorer's Avatar
F-250 restorer
F-250 restorer is offline
A member contacted me. He has a 300, .060 over, over-size valves, p&p head, Comp 252 cam, oem int/exh., 273(?) rears, with OD trans, and he gets 20--22 mpg on the freeway! He said he tach's 2k cruising.
I like that. (Kind of like AB @ 80mph!).
Old 02-06-2011, 11:46 AM
StumpPullerF1's Avatar
StumpPullerF1
StumpPullerF1 is offline
Thats real good, is that with stock sized tires and everything?
Old 02-06-2011, 12:10 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Aside from the oversize valves, that's similar to my van 300, and I'm getting 16-18 cruising at 70 on the freeway without OD. That 252 grind is great for mid range power and makes a very wide sweet spot for economical cruising.
Old 02-06-2011, 12:48 PM
F-250 restorer
31" tires.
Old 02-06-2011, 03:54 PM
F-250 restorer
Weld all thread fittings. You'll be glad you did. It's also a good idea to weld a bead around the end of each pipe, so the hose doesn't slide off.
Old 02-07-2011, 04:37 AM
One79one71's Avatar
One79one71
One79one71 is offline
Ok, Whats are we looking at here??? did u accidentally post this here instead of your plumbing forum???
Old 02-07-2011, 12:11 PM
F-250 restorer
Sorry guys. The member who is getting 22mpg asked about using a Offenhauser intake, and wanted to know about the heating plate needed for the bottom of them. I posted that so he could see what I made for the plate, to get coolant to the spot.
Old 01-26-2013, 04:42 PM
1983F1503004x4's Avatar
1983F1503004x4
1983F1503004x4 is offline
Tell him to sign up here! I wanna hear more about his ride. Pictures would be great too.
Old 01-26-2013, 04:53 PM
Harte3's Avatar
Harte3
Harte3 is offline
Sounds great! Money spent on the head a valves are a good investment even on an otherwise stock engine.
jgdrcr
03-29-2015 06:41 PM
abe
08-06-2013 11:39 AM
6t6merc
03-20-2013 04:18 AM
Dan Robertson
1997 - 2003 F150
17
02-19-2013 05:31 AM
Grendelx
15
12-15-2010 04:53 PM
Quick Reply: 22 mpg w. oversize valves!!
