ISSPRO Fuel pressure guage in cab
Here's my plan:
I want to install swamps single shot injectors this fall. But before doing this I am going to buy ITP's regulated return kit. The kit has the fuel pressure guage included & mounted under the hood.
http://www.itpdiesel.com/store.php?crn=152&rn=277&action=show_detail
But I would like a fuel pressure guage in the cab. Is the extra fuel guage in the cab overkill?
Anyhow, I plan on buying the ovehead guage pod from dieselmanor.com along with the ISSPRO fuel pressure guage & isolator kit.
http://www.dieselmanor.com/dm_products/DM-CGI2240.asp
Can anyone give me some heads up or forsee any problems with the diesel manor fuel pressure guage isolator kit in conjunction with ITP's regulated return? Or am I mixing apples & oranges again...
Am I making any sense
Thanks in advance - Rich
What kind of gauges do you have now? I am saving up for the DiPricol electronic fuel pressure gauge that ITP offers. With this, you do not need an under hood unit that you cannot see anyway. I already have my pod for this along with, who knew, that new HPO gauge, based on what Dennis told me when I was trying to order the older mechanical isolator gauge set.
Anyway Rich, that is the direction I am leaning towards. I have a cheaper gauge I can use to see my idle fuel pressure. I disconnected it. Not needed unless I think I have a problem, otherwise it is just a potential leak.
So no, neither gauge will interfere with the other. If you get a good in cab gauge, you do not need an underhood unit you cannot see anyway. Besides, your most important fuel pressure #s are while underway under a good load. That will tell you if the pump is headed south or some other fuel problem. Even a marginal pump can look good idling our trucks.
Hope that helped
Mike
Hope that helped
Mike
Originally Posted by white Buffalo
Thanks Tenn,
I'll check into the diapercol guages, just thought I would get the ISSPRO since that is what I have already.
You will not regret getting an in cab electric fuel pressure gauge. I watch mine a lot and it can tell you if your pump or filter needs attention. The underhood mech gauge is good for setting pressure at idle, but since you have to put a load on it to see anything happen it is not too useful. The sending unit will screw right into the regulator from ITP.
Did you notice the new Fuel Bowl Delete kit on ITP's site as well? Mines on order.
When I installed my under hood gauge last week, I installed a tee off the fuel bowl housing so I can also (soon, hopefully) install an electronic sending unit on the plugged port on the tee and run it to an electronic gauge in the cab. They're not cheap, typically running around $200 for the sending unit and gauge.
I did, though, find a much less expensive option with a "black out" gauge that I thought really sounded cool. When the power is off, the gauge face is blacked out completely, but lights up bright once the key is turned on.
http://www.jegs.com/webapp/wcs/store...63481_-1_10339
Does anyone know of any problems with these B&M gauges?
I have the in cab electric fuel pressure gauge as well. Very handy troubleshooting aid. I see that ITP also has the hpop gauge as well. Time to petition Congress (ie wife) for more money!
Originally Posted by John311t
That my next gauge also is the HPO gauge. SHould be an interesting gauge to watch....
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_763481_-1_10339
